12mm p pump - Dodge Cummins Diesel Forum
98.5-02 24V P-Pump Conversion Discussion of converting 24V trucks from the VP44 stock pump to a P-Pump powered 24V No Advertising ...NO ADVERTISING
post #1 of 3 (permalink) Old 12-20-2012, 05:12 PM Thread Starter
99cummins5spd's Avatar
12mm p pump
I stumbled across this looking for zf 6 information figured it would be something to post as i believe there was a thread somewhere argueing if or if not a 12mm could do 1100cc...but these people say theirs does?!?
Cummins | Sound Diesel
2002 24V CUMMINS QCSB NV4500,4x4,SB 3600 DD,CPP traction bars,SMARTY,HRVP44,CPP7X.012s,HX35,ARP studs,Airdog 165,FP,EGT,BOOST..p7100 pumped soon..Black 1995 12valve 4X4 RCLB 47RH auto work truck, KDP tabbed..stock for now, 1995 12 valve going into a blue monster
99cummins5spd is offline
post #2 of 3 (permalink) Old 12-25-2012, 01:03 AM
It depends on which oil you run through the pump. Snake oil puts out the biggest numbers.
'92 W250. P-pumped 6.7, 13mm pump,Garrett BB twins.
RonA is offline
post #3 of 3 (permalink) Old 12-25-2012, 10:49 AM Thread Starter
I figured id post it so you guys could see what they are claiming lol
