P-Pump Questions??? - Dodge Cummins Diesel Forum
98.5-02 24V P-Pump Conversion Discussion of converting 24V trucks from the VP44 stock pump to a P-Pump powered 24V No Advertising ...NO ADVERTISING
post #1 of 19 (permalink) Old 04-16-2011, 10:59 AM Thread Starter
P-Pump Questions???
Ok, so I am new to the idea of ppumping my truck but I think it will prolly be the way to go whenever I get some money together to put into my truck (it will prolly be a while with these d*mn student loans, but someday...). I have some questions about the ppump coversion and having a ppump 24V.
Can anbody explain the differences between the different ppumps and which is the best one to make the most hp possible?
How do you get a ppump 24v to make more power? Let me explain a lil, on a vp truck, people use programmers along with injectors, turbos, cams and other stuff to make power. On a ppump 24v, from what I have read, you can't use these programmers, so do you just add big injectors and turbos along with a cam and maybe some other stuff? What are the best ways to get tons of hp from the ppump?
Are there any programmers that can be used with the ppump?
I would also like to know what some of the terminology means when talking about the ppumps:
Benching?
13mm & 12mm?
191 & 131?
Pump Cams?
4ks, 5ks and "clicks"?
Etc.?
I know I am far away from acheiving any of this but I figure if I can get to know more about it before I get there, then i'll be better prepared when the time comes. That and it's fun to learn about all this stuff.
Thank you all
2001 Dodge Ram 2500 2WD Auto 5.9L Cummins: Raptor 150 w/ full 1/2" line kit, DTT Sump, Hypertech 3 Stage programmer, BD Boost Fooler, blocked wastegate, BHAF, 5" RSD exhaust, ISSPRO EGT, boost and fuel pressure gauges.
2001 Hypertech Cummins is offline
post #2 of 19 (permalink) Old 04-16-2011, 01:43 PM
SmokinCummins's Avatar
Best choice for maximum horsepower is a Sigma pump.
Most people are happy with a 12mm p pump tuned for the truck and what you do with it. A vp44 has infinately variable timing meaning it is constantly adjusting timing for the perfect driving conditions. You will never have that with a P-7100. You manually set the timing for what you do with the truck.
Sometimes, people just HAVE to spend money on a mod no matter how useless it is.
SmokinCummins is offline
post #3 of 19 (permalink) Old 04-16-2011, 01:49 PM
There are no programmers or electronics that work with a ppump.
Benching is having the pump calibrated on a test stand for max performance with the parts in it.
13 and 12 mm is the size of the pumping element.
The cam controlls the ramp rate and how radically the fuel is pumped.
191,131 - delivery valves
4k 5k is gov spring rpm range. 4k is 4000rpm 5k is 5000rpm.
The Following 2 Users Say Thank You to SmokinCummins For This Useful Post:
01smokincummins (12-23-2011), 2001 Hypertech Cummins (04-16-2011)
post #4 of 19 (permalink) Old 04-16-2011, 02:43 PM Thread Starter
What is the Sigma pump?
Also, what would be the best pump to use in order to build up a maximum horsepower truck? That is what I want to do someday. I want to push 1000hp on fuel only, or at least get real close to it.
post #5 of 19 (permalink) Old 04-16-2011, 04:14 PM
"I'll go all in."
CumminTryMe's Avatar
iTrader Score: 14 reviews
A sigma pump is a $10k to $15k pump that nobody but the most extreme of extreme trucks need.
"Don't let off, just stand on it! We've got parts!"
Combat Wounded Marine - Some Assembly Required
Originally Posted by HI H.O. SILVER
It's going to be a lot of fun if you like bottle rockets and ninja smoke.
CumminTryMe is offline
post #6 of 19 (permalink) Old 04-17-2011, 12:08 AM
He said maximum power. Just throwing it out there.
To do 1000 horse, I would start with a 13mm race pump. Do you still want to drive it though?
post #7 of 19 (permalink) Old 04-28-2011, 12:54 AM
jkiker's Avatar
i was wondering if yall no if the front case and cover off a 93 cummins would work for a p pump conversion on a 2001? thanks
2001 Silver 2500 EXT LB, 5sp. Southbend Iron Giant,140hp Stix, AutoMeter, FASS, ARP, O-Ringed, Water-Meth, Max spool springs and push rods, more to come by Robbie Love & FBD.
jkiker is offline
post #8 of 19 (permalink) Old 04-30-2011, 12:37 AM
blu_by_u's Avatar
No because the VE pump has a different mounting than the P pump. You could possibly be the first to swap in a VE pump though!
2001.5 CTD ETH 6spd
- P-pump (160hp, 4k gsk, barrels turned, Mack rack plug), Weston's 7x0.010 injectors, Colt Cams 181/210, AirDog 150, BHAF, Tunnel Ram, Kenny's Dual Disk clutch
blu_by_u is offline
post #9 of 19 (permalink) Old 04-30-2011, 01:19 AM
jkiker's Avatar
thanks wan'st sure so figured someone would..... thanks alot
jkiker is offline
post #10 of 19 (permalink) Old 05-07-2011, 05:13 PM
BlackedOut02's Avatar
Ok... The nice...
160, 180, 215, ext: Are the engine horsepower ratings. 215 pumps came off 215hp engines.
181, 191, full cut, lazer cut, ext: Are dilevary valves.
12mm, 13mm, 14mm ext: are the barrel and plunger size of the pump.
You make more power with a p24v by making your pump flow more and adding timing. Just like a 12v.
Now for the not so nice...
If you have to ask questions like these. You have absolutly no buisness messing with a p pump swap or tuning a setup. You need to do mucho homework and searching before you attempt the swap.
Why not start with a 500hp p24v setup first?? From the looks of your sig, you havnt even broke 350hp. Ill bet you will be more than pleased with a 500hp setup.
There is no such thing as a "budget 1000hp p24v". You either need to be able to do all the fab and wrench work your self or have DEEP pockets. Just a 13mm pump will cost 3k+.
Under Construction
BlackedOut02 is offline
post #11 of 19 (permalink) Old 05-08-2011, 03:45 AM
grazmo's Avatar
Hopefully you are going to school to make lots and lots of money to pay someone to work on your truck
01
QC Short Bed, studded 12v swap, 4K GSK, custom ground #100, Aurora 4k
grazmo is offline
post #12 of 19 (permalink) Old 05-08-2011, 04:02 AM
Smourj21's Avatar
iTrader Score: 4 reviews
its going to cost about 4K for a swap...Pump, linkage, gear housing, etc...cam (Might as well since it has to come out anyways), injector lines, not to mention all the misc. stuff you will need to buy.
Like mentioned above...if you have to ask the questions you asked, maybe the swap isnt for you... you will be hard pressed to drive a 1,000 HP P-pump on the street
Just build your VP truck. 500HP is some decent power and can be made pretty easy
02 QCSB 6 Speed|215 P-Pump 600cc 28*|64/S480|SAC 7x12|131 DVs|AD150|Colt 181|HD Push Rods & Springs|ARP/O-Ringed Head|Fluidampr|Valair Tripple Disk|.084 Lines/Tubes|Tunnel Ram|CFM+|Water/Meth|6"Miter|Dana60/80|4.88|True Trac|35" Toyo MT's|
Smourj21 is offline
The Following User Says Thank You to Smourj21 For This Useful Post:
Project Cummins (01-20-2012)
