How much wiring harness? - Dodge Cummins Diesel Forum
98.5-02 24V P-Pump Conversion Discussion of converting 24V trucks from the VP44 stock pump to a P-Pump powered 24V No Advertising ...NO ADVERTISING
post #1 of 8 (permalink) Old 12-10-2010, 02:34 PM Thread Starter
Banned
So supposing I wanna swap in a P7100 into my 2001 model year truck.
At minimum, I know I'd need the gear case, some fuel injector lines, and the proper throttle linkage and cable... However, I'd probably be throwing all sorts of codes.
Could I easily connect the wiring harness and ECM from a 1998 model year 12 Valve to my 2001's PCM? Or could I swap out my 2001 PCM with a 1998 PCM?
Do the PCMs in these trucks have anything to do with the ABS, Airbags, or other functions?
Basically, I'm trying to make a seamless swap... Almost emissions passing if the inspector isn't paying attention.
Pele is offline
post #2 of 8 (permalink) Old 12-10-2010, 03:17 PM
The only difference electrical on my truck is the check engine light is on. I just unpluged all the wiring related to the vp. If you live somewhere that has emissions I'm sure somebody else on here has tried it and can give advice.
2000 2500 qc/lb 4x4 5-speed, GDP fuel boss lift pump, 180 P-Pump,4k gsk.
flcrawler is offline
post #3 of 8 (permalink) Old 12-10-2010, 06:58 PM
kscumminsdriver's Avatar
Not worth the effort... you'd be better off just swapping a complete 12valve with it's full wiring harness and a 12valve dash into your truck...
2013 Ram 2500 Mega Cab 4x4...
kscumminsdriver is offline
post #4 of 8 (permalink) Old 12-10-2010, 11:45 PM Thread Starter
Banned
Why would I put the entire 12 valve engine in?
Just the P-Pump and 12 valve wiring harness and ECM on the 24 Valve engine.
It'd be just like putting a 24 valve head on a 1998 truck.
Pele is offline
post #5 of 8 (permalink) Old 12-11-2010, 12:28 AM
Frankly, I don't understand all of the logistics of swapping over a 12valve wiring harness and ECM and what 24valve sensors you can retain, which ones have to be pitched in the garbage, which sensors from a 24valve can even be used with a 12valve ECM/PCM.... i have no doubt it can be done but then you're just adding more complexity to the Ppump swap.
that's why I say it would just be easier to swap a complete donor 12valve engine, harness and dash into a truck...
post #6 of 8 (permalink) Old 12-13-2010, 07:52 PM
Crammins's Avatar
p pumping your truck will make your check egine light be on for vp codes and possibly cam sensor depending on the year and map sensor. you can take out the check engine light bulb becuase it wont turn off. i dont see the need in swaping in a harness or 12v
98.5 24v w/P7100 850cc's, s485
Crammins is offline
post #7 of 8 (permalink) Old 12-14-2010, 09:25 AM Thread Starter
Banned
Don't need the engine, just the harness, PCM, and from what I'm finding out, the gauge cluster.
12 valve PCM controls the automatic transmission using the TPS/APPS. So I use a 12 valve TPS/APPS on the P-Pump swapped engine and hook it to my 47RE... Or not, I can go manual valve body.
On the 24 valve, the gauges are all controlled by the PCM. So I throw in a 12 valve gauge cluster and all appropriate sensors, wiring harness, etc.
I can't take the Check Engine bulb out, because there is no bulb. It's an LED soldered into the gauge cluster. Plus that doesn't make it stop throwing codes out the OBD2 port. I don't want to throw any codes. Hence why I want to swap in everything properly including 12valve PCM.
I want the PCM to say that everything's working good. I want the OBD2 readings to look legitimately like they would on a properly running 12 valve truck.
You can't pass emissions while throwing codes.
Pele is offline
The Following User Says Thank You to Pele For This Useful Post:
rhino 660 (03-10-2011)
post #8 of 8 (permalink) Old 11-28-2011, 12:55 AM
How goes it
How did u make out with this swap. Mostly the emmisions test
06" qcsb, six speed, 4wd, 5" mbrp, valve springs, 100hp tips,bag o parts(still in box)pmt crazy larry,s&b,sb dd faramic,.425 arp, next compounds and efilive. M923a2
Jayjaytocool is offline
