I changed my oil pan gasket yesterday, I only have 80 bucks and 5 hours worth of wok in it. I took off the intake, valve cover, fan, and the driver side front tire. I jacked the motor up and with the suspension drooped I had plenty of room to pull the oil pan out and get it back on no problem. After the 5 hours of work I have new oil and oil pain gasket but still have my leak. I was almost sure the oil pan was the leak because its coming from the front but it is not wet above the oil pan and the over flow bottle is empty. So its going to my local diesel mechanic...
1997 Regular Cab Long Bed 4x4, Auto, BHAF, #100 Plate, 6" Mitre Cut Stack, KDP Tabbed, 2.5" leveling kit, 35" Dunlop Mud Rovers, 5spd swap in the works.
Ohio Coal Rollers
