Thread: Oil Pan gasket
Old 10-28-2008, 11:49 PM   #9 (permalink)
leatonl
There is no studs for oil pan fasteners. There is a couple of bolts with studs on the end but they are still bolts. With a 2wd you still have to raise the engine but not that much. The motor mounts are slotted so all you have to do is take the nut out and push the bolt out a little. The pickup tube comes off with 4 10mm bolts that you can get to with the pan un bolted.
2007.5 2500 QCSB 4x4 Auto XRT, S&B, 5" TBE, Carli Starter Kit with extras, 285/75 Terra Grapplers
leatonl is offline   Reply With Quote
