| 94-98 Tech Articles Tech Articles for the 94-98 12V Dodge Cummins Diesel...NO ADVERTISING |
47RH Manual Torque Convertor Lock-up switch - NC
First let me say I am no expert at this, but this is information and instructions I have seen posted throughout other forums. There are 2 (two) options you have between switches; a simple on/off toggle switch or a 3 (three) position toggle switch. First off you will need to find PIN 54 and the wire attached to it (orange w/ black tracer). This pin/wire is located in the PCM connector located behind the air filter box on the passenger side of the firewall. Now heres were the 2 (two) options come in for the switch. First is to use a simple on/off toggle switch and ground the wire w/o cutting it. This allows you to either manually lock the TCC or to let the PCM handle it. Your second option for the switch is to use a single pole 3 (three) position toggle switch. To use this switch you cut the wire attached to PIN 54 of the PCM, attach the trans. end to the center pole, attach a ground wire to one of the outside poles, and attach the PCM end of the wire to the other outside pole. It is suggested to use different colored wires when you cut the wire going to PIN 54, so that when extending them into the cab you won't get them confused. Nathan
http://img.photobucket.com/albums/v3...tinb4k/New.gif 1994 2500 Reg. Cab 4x4 SLT Laramie CTD/DTT 330hp/765trq - Work Truck 2002 Ford F150 Super Cab - Daily Driver |
#2 (permalink) |
Excellent info. To carry it just a little farther, with the RE tranny there is a jumper that is required where the lock-up relay is in the power distribution box. Also, with the '96 for a lock-up switch to work properly the PCM needs to be re-flashed. If you don't get the flash, the tranny will go into limp mode. The way I know this is mine just goes into limp. Tom
#4 (permalink) |
Forces the TC to either stay locked, unlocked, or let the trucks computer control it. On/off switch just forces it to stay locked or let the computer handle it.
#6 (permalink) |
I have been reading about this mod. on another Forum and have been thinking about doing this,is there anything else needed besides this three pole switch? Seems simple enough and I love how my truck pulls in Od when the converter locks up and I'm thinking the truck would be much quicker if the converter locked sooner, in secound gear say? I'm a bit worried this might spell the end of this trans though,148000 miles and counting ??
#7 (permalink) |
Just some wire and the switch. Locking up in 2nd really isn't a good idea on a stock trans., 3rd is ok tho. You don't really want to be shifting when locked up either, take about a rough shift, it'll jar ya around pretty good. The main benefit from it is not acceleration, it's cruising and slowing down where it benefits the most. Forcing the TC to stay locked when slowing down and towing helps provide more braking power.
