Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 94-98 Tech Articles
94-98 Tech Articles Tech Articles for the 94-98 12V Dodge Cummins Diesel...NO ADVERTISING
Old 09-12-2006, 06:10 PM   #1 (permalink)
JKM
JKM's Avatar
power windows all the time - NC
Incase any of you want to be able to use your windows with the key off , make a jumper wire to run from the power seat hot terminal , over to the power window fuse (my truck does not have the power seats) the seats are power all the time. Make sure you run the jumper to the supply side of the window fuse , not the load side , so the power is still fused.
Dad's 97 2500 2wd slt laramie, star wheel ahead , afc housing slid ahead. otherwise stock... 5 spd 285k
Mine- 95 2500 4x4, 47rh, Billet TC , shift kit, 285 timberline M/T. Bhaf intake w/ custom heat shield, 5" flo-pro ,147k. 10 plate, 191 dv's, Di Pricol pillar gauges, boost elbow, piers I/C boots timed at 17.5*
On the shelf - 3k gsk, grover air horns
coming soon- Tow mirrors, and Twins?
looking for - 97 or 98 reg cab (or ext cab short box in the 98)4x4 5 sp 12v
JKM is offline   Reply With Quote
Old 09-12-2006, 06:16 PM   #2 (permalink)
Banned
Hey, thats not too bad of an idea...
Dr. Evil is offline   Reply With Quote
Old 09-13-2006, 02:04 PM   #3 (permalink)
JKM
JKM's Avatar
Old 09-13-2006, 05:22 PM   #4 (permalink)
Moderator
You'll wonder how you ever lived without it. Takes 5 minutes tops.
On my truck with power seats I removed the window breaker entirely and jumped from the load side of the seat fuse to the load side of the window fuse. Both the windows and seat are now powered though the same fuse.
Just a 2" jumper with a crimp on spade terminal on one end a a little insulation striped off the other is all you need. Stuff the striped end in female fuse holder then insert the fuse, spade goes on the load side where the window fuse used to be.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Both far from stock
Old 09-13-2006, 06:34 PM   #5 (permalink)
Alt-Tab's Avatar
Y'all are some geniuses, let me tell you. Quick and easy modification but I never would have thought about it. Just another thing to add to my "to do" list!
-- Taylor -- 2004 3/4 ton, 6 speed, 4x4, 185k miles Silencer ring missing, straight piped, AMSOIL 4510, Clearance lights, Mickey Thompson 325/60/18 Baja ATZ's, 2" leveling kit, Predator Stage III
Alt-Tab is offline   Reply With Quote
Old 09-13-2006, 06:39 PM   #6 (permalink)
Hogg Innovations
Bosshogg's Avatar
I know its in the 94-98 forum, but will it work on the newer 2nd gens?
02.5 2500 4X4 reg cab white HO 6spd
Tapped Edge Comp with TST plate and Bosch RV 275 sticks. Stacks by Hogg innovations to roll the coal...
Hogg innovations lift pump/filter big line setup, Multi function shifter stick,Solenoid High Idle
LED's all over, and CF stickers too!!
Bosshogg is offline   Reply With Quote
Old 09-13-2006, 06:42 PM   #7 (permalink)
Alt-Tab's Avatar
Ooh, I didn't notice that. Don't see why not?? I'll try to get around to it by Sunday evening, and if nobody else has replied I'll let you know.
Old 09-13-2006, 09:05 PM   #8 (permalink)
BSouth's Avatar
Maybe a stupid ? but how do you know which is the supply side and which is the load side on the fuse?
05 3500 Yellow 6 speed, Mega cab dually fenders, Rumble Bee Scoop, Edge Juice w/ A2, Striker 2, 5" Silverline exhaust, Icebox with torque tube, Rokktech, Boost fooler, Brite Box w/ Fogzilla
BSouth is offline   Reply With Quote
Old 09-13-2006, 09:22 PM   #9 (permalink)
A good friend
on ours. supply is top, load is bottom..if i remeber correctly.
support your local voulenteer searchand rescue/emergency corps... AVEC347!!
mobs241 is offline   Reply With Quote
Old 09-13-2006, 09:24 PM   #10 (permalink)
Banned
Pull the fuse and use a test light or multimeter
Old 09-14-2006, 02:16 PM   #11 (permalink)
JKM
JKM's Avatar
The Good doctor stabbed that one right on the money...
Old 09-14-2006, 04:16 PM   #12 (permalink)
Works up to 02, I've done 5 trucks so far. One of the best mods made, just watch it around little kids!
gwhammy is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
