Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 94-98 Tech Articles
94-98 Tech Articles Tech Articles for the 94-98 12V Dodge Cummins Diesel...NO ADVERTISING
Old 06-29-2006, 04:34 PM   #1 (permalink)
turbowine's Avatar
Fuel Filter Change - NC
how about a thread on this.how hard is it
2004 Q/C 2500 4X4 A/T (HEMI)
wont be long CUMMINS SWAP/ 6SPD old truck 94 12v
turbowine is offline   Reply With Quote
Old 06-29-2006, 04:41 PM   #2 (permalink)
2001shrtbedcummins
Posts: n/a
It's not to awful hard. On mine there is a spin off top and you pull the filter out. Not sure about a 12valve.
Old 06-29-2006, 04:47 PM   #3 (permalink)
ndurbin's Avatar
Us 12v guys aren't so lucky there shortbus.............
The 94s have the ones that spin on like the oil filter and you need a another joint b/w your wrist and elbow to make it easy to reach under the master cylinder and up to the filter. But it can be done w/o the extra joint.
http://img.photobucket.com/albums/v3...tinb4k/New.gif
1994 2500 Reg. Cab 4x4 SLT Laramie CTD/DTT 330hp/765trq - Work Truck
2002 Ford F150 Super Cab - Daily Driver
ndurbin is offline   Reply With Quote
Old 06-29-2006, 04:58 PM   #4 (permalink)
2001shrtbedcummins
Posts: n/a
don't hate
Old 06-29-2006, 05:01 PM   #5 (permalink)
ndurbin's Avatar
Originally Posted by 2001shrtbedcummins
don't hate
Whats to hate? Being over-valved w/ a crappy fuel supply system, no thank you..............
Old 06-30-2006, 05:57 PM   #6 (permalink)
Moderator
The trick that makes changing the filter on a pre '97 with vacuum assist brakes a breeze is to remove the two nuts that hold the brake master cylinder to the booster. Even though it doesn't look like it the whole master will then move easily towards the driver's side giving you a ton of room to work. With this method the spin-on type filter is much easier to change than the newer cartridge type.
Another trick I use that makes it easier is to open the bleed screw on top of the filter mount then pressurize the fuel tank with compressed air, 10 psi max, though the fill spout. You can use a blow gun wrapped in a rag or make what I have, an old fuel cap with an air chuck tapped into the top.
With this method it takes about 15 seconds to fill and purge the air from an empty new filter.
Sure beats pumping the primer button for half an hour.
Remember to clean the bottom of the sediment bowl and the sensor prongs for the water in fuel while you have it off.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Both far from stock
Old 07-01-2006, 03:47 AM   #7 (permalink)
turbowine's Avatar
did it last night it was easy
Old 12-17-2007, 04:29 PM   #8 (permalink)
Moderator
Monster Truck's Avatar
Did it yetsterday took about 10mins, as easy as changeing the oil filter but you have to have a good filter wrench, I also did it while spilling as much fuel as possible but I was in a spot where I could spill without and problems.
95 Ext Cab SLT, Loaded, built 5spd with hurst, 3.54s, Leveled 4'' Lift 35'' Toyos, optima redtops, 4'' Straight into a 5'' bed kit with 6'' Mitres, Protech, Super B 57/66/14, Stage 2 Sticks, 3GSK, #60 Valve Springs, Stage 2 clutch, BHAF, Plateless, Boost and EGT on the pillar fuel pressure on the colum.
Monster Truck is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
