| 94-98 Tech Articles Tech Articles for the 94-98 12V Dodge Cummins Diesel...NO ADVERTISING |
I have not had the experience of the dreaded death wobble with my truck primarily due to the fact it is a 2wd. However, I have read where a lot of others with the 4wd have had the experience. The common problem seems to be a worn trac bar. I have also heard of worn ball joints contributing to the problem. Essentially any worn component in the front end is a contributing factor. From what I have been able to gather the real problem is a caster problem. Caster is what makes the wheels want to return to the straight ahead position. Without enough caster a wheel doesn’t want to return to the straight ahead position and then you get a ‘fight’ between both tires. I have read that the best caster settings are at the high side of factory specs (+5.5 to -6) The big problem here is the alignment techs don’t understand what causes things to happen so they don’t know what to change to correct a given problem. Just because a unit is in specks doesn’t always fix things. There are TWO things that will cause a DW. #1 Harmonic balance of ft. wheels. #2 Caster setting.. Lets start with Harmonic balance. There are TWO balance conditions of wheels . STATIC and HARMONIC. Static is up and down bounce of the wheel. Harmonic is side to side wobble. IF the harmonic balance of a wheel is OK but the static is off by 5 oz and the wheel balance man fixes the static by hanging 5 oz wt. on one side of wheel ,then he fixed the static but has caused a harmonic imbalance. The wt. must be split and 2 1/2 oz be put on each side of wheel to maintain the harmonic that was correct to start with. Now most wheels will be off on both static and harmonic. That’s why you see wt. opposite each other and spread around wheel. Now #2. Caster . Caster is the imaginary line drawn up and down through the center of the ball joints. If that line is exactly straight up and down you have 0 degree caster and 0 degree camber. If that line leans to the outside on top 1 degree you have positive camber 1 degree. If it leans in toward center of truck 1 degree you got negative camber 1 degree etc. If line leans to the front on top 1 degree you got 1 degree negative CASTER If it leans to the rear on top 1 degree you got 1 degree positive CASTER etc. Positive caster will make the wheel want to turn towards center of truck, negative caster will make the wheel want to turn out away from truck. These caster settings should be within 1/2 degree of each other to counter balance the pull of the other wheel. Think of a grocery cart and the way the front wheels sometimes wobble. That is essentially what is happening when the death wobble strikes. The front tires are wobbling back and forth so violently that there have been reports of the tires actually leaving the ground. As was mentioned earlier have them set the caster to the top end of specks. Well you gotta know where its set at now. If its at o degrees setting at top of specks will sure change things. But what if its already set at top?? Another thing, just what speed does this wobble take place at.?? TOO much positive caster can cause a LOW speed wobble 10-15 mph. If you got a wobble at 10-15 mph, and your wheels ARE balanced, Then find out what the caster settings are and go 3-4 degrees negative, keeping them within 1/2 degree of each other. with the right wheel being the more positive . This gives you a hair left pull to compensate for road crown. If you got a high speed wobble 35-40 up, then more positive caster will stabilize more. Worn parts don’t cause the DW. Good stiff parts cover it up and resist it. The front end really takes a beating when the wobble happens so you will need to inspect ALL parts. If there is any wear found, it must be fixed. Then try to find a good alignment shop. Goober (Tom)
#2 (permalink) |
Posts: n/a
WOW, alot of good info here guys, read it and understand it then go check your truck out and make sure all steering components are in good shape then let the allignment techs check out the rest, its named Death Wobble for a reason, dont be a victom but rather be proactive on maintenance issues. Cheers, Kevin |
#3 (permalink) |
![]() Join Date: Nov 2005
I had one take off on me at about 45 mph and I thought I was done for. It’s not funny till you get it under control and after you went though every 4 letter word you could think of. I looked like the kid in my avatar
#4 (permalink) |
![]() Join Date: Dec 2005
Location: IDAHO check events forum for idaho event info
yep,,,,,,,,,scary. i had that prob on a 95 ferd f350. track bar location bracket kept loosening up. when it happens ya think the world is coming to an end.
for IDAHO discusion and events check www.idahobombersforum.com |
#5 (permalink) |
Good job Tom, I couldn't have said better myself.
2001 Quad Cab 2500 L/B With some bolt on parts. 568hp 1064fpt at Hitech Motors March 28th, 2006 with many new changes since
