Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 94-98 Tech Articles
94-98 Tech Articles Tech Articles for the 94-98 12V Dodge Cummins Diesel...NO ADVERTISING
Old 04-13-2006, 07:10 PM   #1 (permalink)
ndurbin's Avatar
1994-1996 PCM Fault Codes - NC
To get the PCM codes you cycle the key ON-OFF-ON-OFF-ON. Then you watch the check engine light and count the flashes. So as an example code #12 would flash-short pause-flash-flash.
http://dodgeram.org/tech/dsl/trouble..._DTC_codes.htm
http://img.photobucket.com/albums/v3...tinb4k/New.gif
1994 2500 Reg. Cab 4x4 SLT Laramie CTD/DTT 330hp/765trq - Work Truck
2002 Ford F150 Super Cab - Daily Driver
ndurbin is offline   Reply With Quote
Old 04-13-2006, 09:54 PM   #2 (permalink)
Banned
Nathan, I believe this works on a 97 12V as well...but not on the 98 12V's. For them you need an OBDII code reader.
Dr. Evil is offline   Reply With Quote
Old 04-14-2006, 12:46 PM   #3 (permalink)
ndurbin's Avatar
It very well could. I believe Dave's page mentions something about the 97-98s needing to use a DRB tool to read the codes tho.
Old 04-14-2006, 07:39 PM   #4 (permalink)
Moderator
The '97 is a misprint on Dave's page.
The only years the key on/off trick doesn't work on is '98 &'99
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Both far from stock
Old 02-12-2007, 06:43 PM   #5 (permalink)
97 and up required to have OBD2?
Stored diagnostic codes can be displayed by turning the "ignition" key ON-OFF-ON-OFF-ON Within three seconds. The fault codes will flash on the "CHECK ENGINE" light located at about the 8:00 position on the tachometer face. This procedure works for the 94-96 12 Valve engines. The 97-98 12 valve and the ISB all require the DRB diagnostic tool to obtain trouble codes.
As an example, a 23 code would be indicated by FLASH, FLASH, PAUSE, FLASH, FLASH, FLASH. Multiple codes may be displayed, and the sequence always ends with 55. Green codes will light the CHECK ENGINE lamp when the engine is running.
CODE MEANS
11 No crank signal detected during cranking
12 Battery was disconnected within the last 50 key-on cycles (Resets after 50)
15 No vehicle speed/distance signal while driving
23 Intake manifold air temp sensor voltage too high or too low
24 Throttle position sensor voltage too high or too low (automatic only)
33 An open or shorted condition detected in the AC clutch relay circuit
34 Open or short in the Speed control solenoid circuits or
Speed control switch voltage too high or too low
37 Open or short in the Torque converter clutch solenoid CKT circuit or
Voltage high or low at transmission Temperature sensor
41 An open or shorted condition detected in the alternator field control circuit
42 An open or shorted condition detected in the Auto Shutdown Relay circuit
44 An open or shorted condition detected in the engine coolant temp sensor circuit or
A problem exists in the PCM battery temperature / voltage circuit
45 An open or shorted condition detected in the overdrive solenoid circuit
46 Battery charging system voltage too high
47 Battery charging system voltage too low
53 Internal PCM circuitry or communication failure
55 End of sequence. Last code sent to indicate the end of the codes.
62 SPI miles not being updated as vehicle travels
63 Unsuccessful attempt to write to EEPROM by the PCM
hyper is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
