| 94-98 Tech Articles Tech Articles for the 94-98 12V Dodge Cummins Diesel...NO ADVERTISING |
Cummins Fan/ TECH SPECIALIST
94-02 Part Numbers
moog numbers: 94-02 2wd part numbers: 02-94 adjuster sleeve: ES2080S 99-94 adjuster sleeve: ES2080S 02-00 tierods: ES3540 outer right, ES3539 inner right, ES3539 inner left, ES3540 outer left 99-94 tierods: ES3172RLT outer right, ES3171RLT inner right, ES3171RLT inner left, ES3172RLT outer left 02-00 solid axle 3500 HD tierods: PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1460, adjuster sleeve ES21012S, pitman arm tierod ES3527. LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1462, adjuster sleeve ES21012S, left tierod ES3526. 99-98 solid axle 3500 HD tierods: PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1459, adjuster sleeve ES21012S, pitman arm tierod ES3497. LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1456, adjuster sleeve ES3498S, left tierod ES3496. track bar: DS1413, replacement bushing: K7252 97-94 solid axle 3500 HD tierods: PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1309, adjuster sleeve ES21012S, pitman arm tierod ES3249RT. LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1308T, adjuster sleeve ES21012S, left tierod ES3248RT. track bar: DS1256 before 2/7/94, DS1413 after 2/7/94, replacement bushing K7252 99-94 solid axle 3500 HD REAR tracbar K7382 02-00 upper balljoint: K7366 99-94 upper balljoint: K7206T 01-00 lower balljoint: K7365 99-97 lower balljoint: K7269 96-94 lower balljoint: K7205T 99-94 upper control arm bushing kit: K7276(2 per truck) 99-94 lower control arm bushing kit: K7277 2WD STRAIGHT AXLE 3500HD: 02-00 upper balljoint: K7397 99-94 upper balljoint: K8388T(enhanced design) 02-00 lower balljoint: K7397 99-94 lower balljoint: K8607T(enhanced design) 99-94 upper control arm bushing kit: K7278(2 per truck) 02-94 swaybar link kit: K7275 99-98 3500 w/ straight ball stud swaybar link kit: K7300 99-96 3500 w/ tapered ball stud w/ solid axle swaybar link kit: K7280 97-94 3500 w/ straight ball stud w/ solid axle swaybar link kit: K7299 97-94 3500 w/ straight ball stud w/ solid axle swaybar link repair kit: K7300 ***PM ME: for swaybar to frame bushing kits, too many to list*** 02-00 2500 w/ 7500lb GVWR idler arm: K7347, pitman arm: K7345 99-95 2500 w/ 7500lb GVWR idler arm: K7217T(HD), pitman arm: K7239 99-95 2500 w/ 8800lb GVWR idler arm: K7225T(HD), pitman arm: K7238 02-00 3500 IFS idler arm: K7347, pitman arm: K7345 99-95 3500 IFS idler arm: K7225T(HD), pitman arm: K7238 1994 2500 w/ 8800lb GVWR idler arm 2nd design 16mm bolts: K7225T(HD), pitman arm: K7238 1994 2500 w/ 8800lb GVWR idler arm 1st design 14mm bolts: K7237, pitman arm: K7238 1994 3500 IFS idler arm 2nd design 16mm bolts: K7225T(HD), pitman arm: K7238 1994 3500 IFS idler arm 1st design 14mm bolts: K7237, pitman arm: K7238 moog numbers: 94-02 4wd part numbers: ***ALL NUMBERS ARE FOR DANA 60 AXLE*** 02-00 trackbar: DS1413 02-00 tierods: PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1460, adjuster sleeve ES21012S, pitman arm tierod ES3527. LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1462, adjuster sleeve ES21012S, left tierod ES3526. 99-98 trackbar: DS1413 99-98 HD tierods: PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1459, adjuster sleeve ES21012S, pitman arm tierod ES3497. LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1456, adjuster sleeve ES3498S, left tierod ES3496. 97-94 trackbar: DS1256 before 2/7/94, DS1413 after 2/7/94, replacement bushing K7252 97-94 solid axle 3500 HD tierods: PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1309, adjuster sleeve ES21012S, pitman arm tierod ES3249RT. LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1308T, adjuster sleeve ES21012S, left tierod ES3248RT. 02-00 pitman arm: K7339 02-00 upper balljoint: K7397 99-94 upper balljoint: K8388T(enhanced design) 02-00 lower balljoint: K7397 99-94 lower balljoint: K8607T(enhanced design) 99-94 upper control arm bushing kit: K7278(2 per truck) ***IF I MISSED ANYTHING GUYS LET ME KNOW AND ILL ADD IT***
1990 D250, RC LB, 2WD, 130,000 MILES, 727, NOT ENOUGH ROOM TO FIT MODS ONE OF THE FEW, THE PROUD, AND THE VE POWERED Last edited by LOGAN : 08-23-2007 at 12:20 AM. |
#2 (permalink) |
Super Administrator
![]() Join Date: Jan 2006
Great Job Logan, Thank You !!!!!!!!!!!!!!:thumbsup
![]() 03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph) July 2009 Cummins Forum ROTM Winner 95 1500 Sport 2wd Cummins Drag Truck under construction. "In search of the Magic Dyno"
#3 (permalink) |
all those part numbers is the reason i will stay with my 1st Gen from now on, we dont have half those numbers that the 2nd gen trucks do. I had a 2nd Gen V10 truck and was nothing but trouble at higher mileage, motor=fine, truck=junk.
1990 D250, RC LB, 2WD, 130,000 MILES, 727, NOT ENOUGH ROOM TO FIT MODS ONE OF THE FEW, THE PROUD, AND THE VE POWERED |
