Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 94-98 Tech Articles
94-98 Tech Articles Tech Articles for the 94-98 12V Dodge Cummins Diesel...NO ADVERTISING
Old 02-10-2006, 02:58 PM   #1 (permalink)
ndurbin's Avatar
Home Made Throttle Control/High Idle Set-up - NC
Whole reason for this thread was lately I had been feeling bad letting my truck idle while it's cold. Fear of cylinder wash I guess.
So I ran down to the local NAPA, picked up a 5' throtte control cable for $12. Cut off all but 2' of it. Found the mounting place I wanted, on the knee bolster below and left of the steering column. Drilled thru the plastic and the arm for the gas pedal. Fished the wire thru wrapped it around acouple times and bota-bing bota-boom I had man. throttle control and high idle function.
One thing I learned is it's impossible to take the gas pedal off and also nearly impossible to fit a med. sized drill in behind the dash support and still be able to drill. SO take the lower dash support piece out and stick a block (pliers in my case) between the gas pedal arm and the firewall. Makes drilling a piece of cake.
I will have more pictures to come shortly. But here is the mounting location for the push/pull button.
http://img.photobucket.com/albums/v3...tinb4k/New.gif
1994 2500 Reg. Cab 4x4 SLT Laramie CTD/DTT 330hp/765trq - Work Truck
2002 Ford F150 Super Cab - Daily Driver
ndurbin is offline   Reply With Quote
Old 02-10-2006, 07:56 PM   #2 (permalink)
Tech Specialist/Moderator
SmokinDiesel's Avatar
Wow ... Slick idea
Good job!
Mike Charlton - Keystone Diesel
1996 Dodge Cummins 12 Valve
566.5 hp - 1000+ ft lbs
Shooting for 600+ ....
SmokinDiesel is offline   Reply With Quote
Old 02-11-2006, 08:02 AM   #3 (permalink)
Banned
excellent work nathan...Ive been thinking about doing this. I was looking at a fancy cable but its kind of pricey:
http://www.awdirect.com/awdirect/cat...ion&linkid=210
Did you run the cable through the firewall to the throttle linkage? Any more info would be great.
Dr. Evil is offline   Reply With Quote
Old 02-11-2006, 08:14 AM   #4 (permalink)
ndurbin's Avatar
No.......it's all in the cab behind the knee bolster and under the dash. I'm going to snap somemore pictures today sometime.
Old 02-11-2006, 08:51 AM   #5 (permalink)
ndurbin's Avatar
1st pic shows the cable going thru the knee bolster.
2nd pic shows the hole drilled into the gas pedal arm. Really fuzzy for some reason.
3rd pic is an overall shot.
I forgot to mention to zip tie the cable up outta the way.
Old 02-11-2006, 04:13 PM   #6 (permalink)
Trapper's Avatar
Hey that a great Idea, I though I was South Of Lubbock on my cruise control for my cummins conversion
Trapper is offline   Reply With Quote
Old 02-12-2006, 06:52 AM   #7 (permalink)
Banned
Yup - second one is a lil out of focus
Nice job - I will have to do this mod - it sure beats the old stick jammed between the go pedal and seat
Old 02-12-2006, 10:03 AM   #8 (permalink)
ndurbin's Avatar
I've yet to see how well it holds going down the road but does fine holding it at a set RPM idling. If nothing else you could go buy a small wooden dowel rod and cut a groove in it to slip over the shaft attached behind the button. Then trim the length to get it to hold a certain RPM. They do make some cables that lock into position tho so that might be better if one was to use it for cruise control.
Old 02-12-2006, 10:22 AM   #9 (permalink)
Moderator
Don't know that I'd want to use a setup like that for cruise especially with an auto because it won't disengage when you step on the brakes.
You might just keep on going...
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Both far from stock
Old 03-18-2006, 02:44 PM   #10 (permalink)
will you post some more pics of this? I'm trying to convince my pops to do this to his 98 12 valve.
2001.6 HO. BHAF, cool duals, catcher, vulcan lp relocation, fp/boost/pyro on a pillar, extang bed cover
jeepmullet is offline   Reply With Quote
Old 03-18-2006, 04:03 PM   #11 (permalink)
ndurbin's Avatar
Anything specific you want pics of? I will snap some more tomorrow.
Old 03-18-2006, 06:21 PM   #12 (permalink)
anything that would make a blind idiot be able to do the install with one hand, a stick of bubble gum, and some wd40
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
