Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 94-98 Tech Articles
94-98 Tech Articles Tech Articles for the 94-98 12V Dodge Cummins Diesel...NO ADVERTISING
Old 01-05-2007, 03:40 PM   #25 (permalink)
Alt-Tab's Avatar
Ok so apparently this doesn't work on my truck. Everything went (fairly) smoothly, and when I was done, the throttle always wants to return to idle. No way of holding it open....apparently the spring is too strong?
Anybody know if the dealer can change a setting on my 2001 so I can use the cruise control buttons?
-- Taylor -- 2004 3/4 ton, 6 speed, 4x4, 190k miles Silencer ring missing, straight piped, AMSOIL 4510, Clearance lights, Mickey Thompson 325/60/18 Baja ATZ's, 2" leveling kit, Predator Stage III
Alt-Tab is offline   Reply With Quote
Old 01-05-2007, 04:23 PM   #26 (permalink)
The cable I used has a lock feature. You pull it out to increase the speed, then twist it to lock it in place.
Mighty Dodge is offline   Reply With Quote
Old 01-14-2007, 03:50 PM   #27 (permalink)
Platinum Powerstroke Mod
Maintain's Avatar
There was an IDLE up option installed on an 80's model GMC Sierra 3500 Camper package conversion to a flatbed car hauler. It has a Carb'd 350 w/ manual trans. The cable was rigged directly to the throttle with a small necklace looking chain that broke. I replace the chain with 3 heavyduty zip ties (2 were zipped tight to hold the other one in between). Works like a charm and I can either idle it up 1-300 rpm's or pull her wide open (not that I'd need to) to operate the bed/winch - it's really fast now!
I plan on doing this to my jeep too after mounting the winch so that I can idle her up while pullin people out!
2001 F250 Platinum Edition
12 something or other at about 105 mph at 7500 lbs.
Maintain is offline   Reply With Quote
Old 01-15-2007, 04:07 PM   #28 (permalink)
bbraden's Avatar
Any pictures of this? Or is it on a Powerstroke?
99 dodge 4x4 13" Proluk Gold clutch, BHAF-K&N combo, Super X VP44, FASS, Edge comp, MODIFIED Super B Turbo, RV 275's, Quick spool manifold, 4" MBRP straight back, 3.55's, BFG A/T 285's!, somewhere north of 400 hp
bbraden is offline   Reply With Quote
Old 01-28-2007, 01:52 PM   #29 (permalink)
ttbird's Avatar
here's another choice.
AWDirect.com - ET100 Electric Throttle Control Kit
1995 ext cab 4X4, 4"bd exhaust w/o cat, afe intake/outerwear,3000 gov., #5 fuel plate, Phat 62,191 dv's,370,timing 14, kdp tabbed, x-monitor; pyro, trans, boost, dss, luke's link, Bob V's 2-lo kit, signal mirrors, line of fire, parking light strobes, led ip, 1 3/16" rear slave cyl., prothane bushings, blistein shocks, Goerend Trans.
ttbird is offline   Reply With Quote
Old 02-03-2007, 05:20 PM   #30 (permalink)
schoust's Avatar
Hey Mghty Dodge where did you get the locking cable from?I'm thinking this is the best way to do it......
schoust is offline   Reply With Quote
Old 02-04-2007, 06:23 AM   #31 (permalink)
Well actually I got it at a yard sale. Some garden tractors used a locking throttle cable, Wheelhorse, Bolens come to mind. I have seen them on ebay.
Old 02-04-2007, 06:57 AM   #32 (permalink)
ndurbin's Avatar
Most auto parts stores carry a variety of cables.
http://img.photobucket.com/albums/v3...tinb4k/New.gif
1994 2500 Reg. Cab 4x4 SLT Laramie CTD/DTT 330hp/765trq - Work Truck
2002 Ford F150 Super Cab - Daily Driver
ndurbin is offline   Reply With Quote
Old 02-05-2007, 07:34 PM   #33 (permalink)
dcanmech's Avatar
i have done the same with a locking cable and it works great. the only thing different was i put the cable on the right side of the column so its a straight line to the pedal. but regardless works great....
Cummins power all the way!!! But for me its in a chev
dcanmech is offline   Reply With Quote
Old 03-19-2007, 01:15 PM   #34 (permalink)
CPS'kid@vt's Avatar
ndurbin, what are your other switches for...j/w...and what is the benefit of having high idle....sorry, i'm all gas right now, cummins as soon as the xj breaks.
CPS'kid@vt is offline   Reply With Quote
Old 03-19-2007, 07:24 PM   #35 (permalink)
DIESEL HEAD
Got any pictures of the idle setup.
2005 RAM 3500, QUAD-CAB, 6-SPEED, 2WD, 50K MILES, MUFFLER IS MIA
1-TON is offline   Reply With Quote
Old 04-11-2007, 03:20 PM   #36 (permalink)
ndurbin's Avatar
From Left to Right: Reverse work lights, Tool box lights, fog lights, and Off-road lights on the headache rack. I have two more lighted rocker switches on the dash (next to the OD button) to control my exhaust brake and H2O/Meth. system (once it's installed).
Benefit of using the high idle is keeping the EGTs over 300* to prevent cylinder wash during prolonged idling.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
