| 94-98 Tech Articles Tech Articles for the 94-98 12V Dodge Cummins Diesel...NO ADVERTISING |
#13 (permalink) | |
#14 (permalink) |
Moderator
nice idea on this, my buddies 97 3500 chevy has thesame concept for the cruis control, only it came like that from the factory.
95 Ext Cab SLT, Loaded, built 5spd with hurst, 3.54s, Leveled 4'' Lift 35'' Toyos, optima redtops, 4'' Straight into a 5'' bed kit with 6'' Mitres, Protech, Super B 57/66/14, Stage 2 Sticks, 3GSK, #60 Valve Springs, Stage 2 clutch, BHAF, Plateless, Boost and EGT on the pillar fuel pressure on the colum. |
#15 (permalink) |
Here is what i did to mine: High idle solonoid off of an old carb , 5$ at the junk yard. fabbed up a mount and ran a wire to a switch. ![]() Hmm , appears the pic did not work , here is the link: http://img245.imageshack.us/my.php?i...10100841rl.jpg
Dad's 97 2500 2wd slt laramie, star wheel ahead , afc housing slid ahead. otherwise stock... 5 spd 285k Mine- 95 2500 4x4, 47rh, Billet TC , shift kit, 285 timberline M/T. Bhaf intake w/ custom heat shield, 5" flo-pro ,147k. 10 plate, 191 dv's, Di Pricol pillar gauges, boost elbow, piers I/C boots timed at 17.5* On the shelf - 3k gsk, grover air horns coming soon- Tow mirrors, and Twins? looking for - 97 or 98 reg cab (or ext cab short box in the 98)4x4 5 sp 12v |
#16 (permalink) |
That is the same one I saw on my son's 95. Previous owner had it installed. I also when to the wrecker and bought the solenoid (75-newer carbed/air conditioned Chev) for $5. The only difficulty is is making the bracket which can be made from a 3x3 piece of metal folded, ground and drilled. It works well, you rev the engine manually above the solenoids limit and turn it on. It does not have enough power to move the throttle from idle but will hold it after it is actuated.
#17 (permalink) |
This is pretty good guys. I've been lookin into the whole high idle thing but can't bring myself to spend 300 bucks for one....
99 dodge 4x4 13" Proluk Gold clutch, BHAF-K&N combo, Super X VP44, FASS, Edge comp, MODIFIED Super B Turbo, RV 275's, Quick spool manifold, 4" MBRP straight back, 3.55's, BFG A/T 285's!, somewhere north of 400 hp |
#18 (permalink) |
I was pondering the same thing using the kit in the attachment here. I was planning on running it into the throttle linkage under the hood. Any good or bad thoughts on that. Roadless Gear Thumb Throttle Kit: Roadless Gear For Suzuki
99 Quad Cab, 4wd, Comp Box W/Pump Wire & Boost Elbow installed, K&N Air Canon, MBRP exhaust, Twin PE 4200 High Pressure Fuel Pumps W/Fleetguard inline filter, Isspro EV Pyrometer, Boost Guage, Fuel Pressure Guage, DT Pro Fab Trac Bar, South Bend 13-1.25 Con O Clutch, Royal Purple Synthetics all around 374.2/846.7 at 30psi |
#19 (permalink) |
that's pretty nifty too! I usually just synchronize downshifts - say from 5th back down to 4th I just pull out into neutral, and then bring the RPM's up to where it'll just fall back into 4th (matching engine RPM's with trans. rpm's and never touching the clutch) so that I can hold the brake a little with the left foot the whole time that I'm downshifting. That would be pretty neat to have a thumb lever on the shifter like a 4 wheeler though! I'm sure it'd take some getting used to. The only bad thing would probably be trying to get the line through the shifter boot and since we probably have bigger sticks than the Suzuki's - it might not fit around our shifter stick. Other than that, I might be lookin into that!
99 dodge 4x4 13" Proluk Gold clutch, BHAF-K&N combo, Super X VP44, FASS, Edge comp, MODIFIED Super B Turbo, RV 275's, Quick spool manifold, 4" MBRP straight back, 3.55's, BFG A/T 285's!, somewhere north of 400 hp Last edited by bbraden : 12-05-2006 at 09:12 PM. |
#20 (permalink) | |
#21 (permalink) |
Yeah I used to drive big truck too but I heard that it's harder on the flex plate... I dunno about any of that really but I know that it throws a lot of people for a loop when I show em that I can shift without the clutch.
#23 (permalink) |
Just picked up a push/pull cable from Auto Zoo for $5.99, hopefully gonna install this weekend! I'll let y'all know how it goes
-- Taylor -- 2004 3/4 ton, 6 speed, 4x4, 191k miles Silencer ring missing, straight piped, AMSOIL 4510, Clearance lights, Mickey Thompson 325/60/18 Baja ATZ's, 2" leveling kit, Predator Stage III |
