Diference between 1996 & 1998 47RE? - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 02-27-2014, 09:41 PM Thread Starter
jagert59's Avatar
Can anyone tell me the differences between a 1996 and 1998 47RE?
98 Club Cab 12v 4x4 Sport Auto BHAF, Ford Hub Swap, Rokmen Control Arms
jagert59 is offline
post #2 of 7 (permalink) Old 02-27-2014, 10:20 PM
country_hick's Avatar
I can only tell you that on a 2wd there is a difference in some years. My 1997 has 2 electrical plugs in the overdrive section. Some later models only have 1 electrical plug. I think the difference was because the speedometer sensor was moved to the rear axle. I would assume the 4x4 had a similar difference but perhaps not. I do not know the year that changed but that is the only real difference to be concerned with.
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
post #3 of 7 (permalink) Old 02-27-2014, 10:38 PM
mitch13's Avatar
Gear indicator switch, dip stick gasket and one other plug if I remember right.
mitch13 is offline
post #4 of 7 (permalink) Old 02-27-2014, 10:39 PM
SINCE WE'RE ON THE SUBJECT..................
looking at a great deal on a georend trans out of a 99. will i have to modify it to fit my 97? both 47re 4x4
97 CCLB DRW 4X4 AUTO AMSOIL 4510, SILENCER RING MIA, 4K GSK, 60LB. VALVESPRINGS, AUTOMETER Z SERIES BOOST, PYRO, TRANS. STARWHEEL CRANKED A BIT, HOMEMADE 0 PLATE, FULL BILLET SUNCOAST WITH TRIPLE DISC, NEED MORE FUEL!!!!!!!!
darkkevin is offline
post #5 of 7 (permalink) Old 02-27-2014, 10:41 PM
Smokeycummer
Smokes when she drinks's Avatar
I think there the same
97 Eclb 4x4 billet single, 215 pump gutted ,adjustable tork tec ofv , built trans ,upgraded flexplate,4 in dual straight pipe , fp, boost ,trans temp ,and egt Gage's 192000 miles , 4:10s
97 Eclb( 4 door 2002 body) 4x4 ,160 pump,tst 4gsk pdd 5x14s, 191dvs,afc live 2 ,max boost head bolts 135 ft lbs ,stock timeing
Adjustable tork tec , Gage's fp , boost , trans temp , egt , single billet tc upgraded flexplate , built trans , straight pipe dump under cab, bhaf , aftermarket intercooler , pot mod
Smokes when she drinks is offline
The Following User Says Thank You to Smokes when she drinks For This Useful Post:
dozer12216 (02-27-2014)
post #6 of 7 (permalink) Old 02-28-2014, 08:54 AM
bootstrap's Avatar
No.....................
1997 12v NV4500 2500HD 2wd SOLD
bootstrap is offline
post #7 of 7 (permalink) Old 02-28-2014, 08:56 AM
bootstrap's Avatar
My 1997 2wd 47RE had 1 speed sensor plug in the overdrive section and nothing else.
2 plug ins on the main section, drivers side.
