Lift pump - Page 2 - Dodge Cummins Diesel Forum
post #13 of 48 (permalink) Old 11-13-2005, 10:38 PM
Guest
Guest
Posts: n/a
From the problems you describe, timing can be affected by a bad Overflow Valve.
The low pressure release of the overflow valve due to normal wear will slowly degrade and in essence retard the timing of the injection sequence due to a lower inlet pressure to the injector pump. This late timing will cause studdering, and misfire when cold. Also mileage may be an indicator.
replaceing the overflow valve would clear up alot of the problems. Before you pay for a timing adjustment I would definitely go and spend the $75 on an overflow valve and see if it changes anything.. I would bet it would make a significant difference.
Cheers, Kevin
post #14 of 48 (permalink) Old 11-13-2005, 10:40 PM
Guest
Guest
Posts: n/a
you also need to check your afc housing out
and you need to make sure the fuel plate is not missing .... look for the tamper proof screw to be missing that will prove tampering in the pump ...
heres some learning material
http://www.dodgedieseldatabase.com/p...ction_pump.htm
http://www.dodgedieseldatabase.com/p-pump_cut_away.htm
http://www.dodgedieseldatabase.com/12_v.h4.gif
http://www.dodgedieseldatabase.com/t...up_a_p7100.htm
keep us posted
DM
post #15 of 48 (permalink) Old 11-13-2005, 10:43 PM
Guest
Guest
Posts: n/a
here's where the brake off (tamper proof Screw is ..
Is it intact
DM
post #16 of 48 (permalink) Old 11-13-2005, 11:00 PM
Guest
Guest
Posts: n/a
The overflow valve would be key suspect to me, I have read of folks with symptoms like you describe and one thing fer sure it doesnt hurt to renew it once in a while, get that truck goin again and its off to the races [IMG][/IMG]
post #17 of 48 (permalink) Old 11-13-2005, 11:01 PM Thread Starter
Tech Specialist
AZBLACKSMOKE's Avatar
Cheers, Kevin
Where is the overflow valve at?
2001 GMC 2500HD, crewcab,LB, 4x4, duramax, ZF6, Southbend SD, organic, hypertech.
1989 C3500 reg cab flatbed, 6.2, GM4 turbo, Was TH400, process of installing NV4500.
I LOVE the CTD...I just dont like the shipping container it comes in.
AZBLACKSMOKE is offline
post #18 of 48 (permalink) Old 11-13-2005, 11:04 PM
Guest
Guest
Posts: n/a
I would say you have a slight Fuel Delivery Issue
First thing to do is start cracking injectores just 2 people
have the driver hold it where its missing real bad
then pop the hood and remove the first injector line at the pump it will squart diesel all over ,,,when the line is cracked on the fist one ,,,,does it sound better ?????? if not keep going if you find oine that straited it up then that injector is bad ...if none of them straiten up how its running then the prople is in the pump we will move on .................
After ruling the easy stuff out ....we go deeper like timing adjustment if we have to
good luck I hope its an easy fix for you
Your looking to see if its been messed with if the tamper proof screw is present then dont mess with it ....till later :>
If its gone then we'll go from there
DM
post #19 of 48 (permalink) Old 11-13-2005, 11:06 PM
Guest
Guest
Posts: n/a
DM
post #20 of 48 (permalink) Old 11-13-2005, 11:07 PM
Guest
Guest
Posts: n/a
Right on the pump where the return line comes back in , here is a link to more info on it overflow valve
I do agree that it is common for the timing to slip but the symptoms they listed there can overlap with other things as well.
The OF valve is probably the single item the wears out most often on a 12 valve.
Precision Diesel Injection and Turbo Inc.
Marty Tompkins
888-734-7349
$35 + $5 shipping and handling.
Replacement takes one wrench and five minutes.
If you don't have a gauge symptoms are:
low RPM miss/instability
white smoke
hard starting
engine dies at idle
low power
fuel filter cracking
post #21 of 48 (permalink) Old 11-13-2005, 11:09 PM
Guest
Guest
Posts: n/a
Boy I tell ya that DM has a quick puter and fingers that know how to run it
post #22 of 48 (permalink) Old 11-13-2005, 11:10 PM Thread Starter
Tech Specialist
WATCH THIS VIDEO .....
http://www.dodgedieseldatabase.com/12vv.zip
IS IT DOING THAT ??? Or something similar ?
DM
Sorry for the slow replys..my computer is acting up.
My situation is very similiar to the video. It sounds the same except mine is doing it at 2000rpm, and the the truck in the vid. looks like it was doing it at 1100rpm.
Slightly different rpm's, but they sound the same. Excellent video.
What do I look for when I have the afc housing off? Cracks, crap? besides making sure it hasnt been tampered with. i will look closely at the links/info you gave me and keep ya'll posted. thanks.
post #23 of 48 (permalink) Old 11-13-2005, 11:15 PM Thread Starter
Tech Specialist
DM
I'll try that tomarrow. Thanks.
post #24 of 48 (permalink) Old 11-13-2005, 11:18 PM
Guest
Guest
Posts: n/a
Didnt you post this once already
Look on page 2 for the reply >..LOL
Thanks Whity by god we'll get his truck back on the road or our mother boards will fry
The truck in the video was attemped to be fixed by ...
Over flow valve
Delivery Valves
Pre filter cleaning
and a few more things ...what fixed it was
Smaller injectors and 3kgsk and afc work
this is a 160 pump truck that had 370's in it we thought the 370's were bad so we bought a new set of 370's ..it didnt fix it ..
we went to stock injectors and it fixed it 75%
the 3kgsk took care of the rest ...
you truck is a diffrent animal tho ,,,the reason the truck in the video was struggling was that the pump was to small to run the injectors without other other mods being done ..
you pump is big enough so there has to be something else wrong but with simalar symtoms.
So Check the injectors
check for the tamper proof screw
and swap in your CTD neigbors Over flow valve
then go from there
DM
