Help!! Ticking noise - Dodge Cummins Diesel Forum
Old 11-07-2008, 11:35 PM   #1 (permalink)
Suzuki4life05's Avatar
In the past two weeks my cummins has developed a ticking noise. It only happens at idle thru about 1250rpms. Sometimes it is louder than others, and sometimes it doesn't even do it at all. I have tried the screwdriver stethescope technique and i swear i could've heard it one time in between the oil pan and the bell housing of the tranny. Fly wheel and everything looks fine along with the starter. But after that i can't seem to hear it there anymore.
It sounds like it may be coming from the valve cover area, but it can also be heard pretty clearly through the driverside fender well.
Any help with this will be greatly appreciated as i am at my wits end.
1997 3500 CTD auto, TST #8 fuel plate most of the way foward, Silencer ring MIA. star-wheel maxed,3K gsk, bhaf, 5" straight pipe, 2" coil spacers, 255/85/16 coopers
78,000 miles and counting
Suzuki4life05 is offline   Reply With Quote
Old 11-08-2008, 12:20 AM   #2 (permalink)
CumminsBeast's Avatar
My 06 does it all the time, but I would think it uncommon for a 97. Heard plently of 06 with the problem. Mine was carbon buildup, helped out by the low sulfur diesel we now have to run according to a couple sources. I'm no expert, but the low sulfur diesel may be affecting yours too.
Diesel-less at the moment
CumminsBeast is offline   Reply With Quote
Old 11-08-2008, 10:16 AM   #3 (permalink)
after some research i have found this may be the issue too. Im going to change the fuel filters today and add some 2cycle oil so we will see if that helps
Old 11-08-2008, 11:28 AM   #4 (permalink)
Sounds like mine. Mine is the lift pump, when it's idling push the primer in and see if the if the tick goes away.
1997 2500 4x4 bone stock, on the way...5" pipes, 3k GSK, 100hp sticks, BHAF and BD Super B
KBdiesel is offline   Reply With Quote
Old 11-08-2008, 11:57 AM   #5 (permalink)
Pierson's Avatar
iTrader Score: 7 reviews
not sure what kind of ticking your talking about... mine was ticking under acceleration..I figured it was injector. I ran some PS diesel kleen through it and it went away.
06 Mega DRW
07.5 QCLB DRW G56
02 LB7 Dmax
Pierson is offline   Reply With Quote
Old 11-08-2008, 12:24 PM   #6 (permalink)
kain3809's Avatar
sounds like your lift pump. I had the same thing. got an air dog and it went away
03' Stock auto, soon to be 5 speed
kain3809 is offline   Reply With Quote
Old 11-08-2008, 12:39 PM   #7 (permalink)
aautio1004's Avatar
I get a ticking on mine from mthe drivers side fender area..I'm pretty sure it's my IP as it'll get quieter and louder from time to time depending on how much 2stroke I put in the fuel for lube
'01 2500 4x4 QC/SB, 4" straight pipe, Amsoil intake, Autometer gauges,Smarty,Edge Comp Hot,Holley Blue,HX40,Recon roof led's, manual high idle, built up auto trans, 89% stall TC
'07 Chev 2500 CC/LB Duramax LBZ Edge Juice with Attitude
aautio1004 is offline   Reply With Quote
Old 11-08-2008, 01:50 PM   #8 (permalink)
i feel like the 2 cycle will help, this ulsd probably isnt helping anyway. My ticking goes away after about 1250rpms , the ticking gets faster up until that point and then just goes away.
And where is the primer located?
Old 11-09-2008, 04:25 AM   #9 (permalink)
Big Smoky's Avatar
It's the rubber button on the side of the lift pump. The ticking noise is most likley the LP. It does it when it's on it's way out (even though some pumps do it forever before they go), or if you have stretched the overflow valve spring to up the fuel pressure.
Truckless
Burned in wildfires...R.I.P.: '95 3500, Reg. Cab, 4x4
Eric
Big Smoky is offline   Reply With Quote
Old 11-09-2008, 10:26 AM   #10 (permalink)
Update- changed the fuel filter and added some 2cycle from walmart, ticking has subsided and i dont believe i have ever heard the truck idle this smoothly before. Its like a whole different truck.
Old 11-09-2008, 12:02 PM   #11 (permalink)
aautio1004's Avatar
That's excellent! Glad to hear that took care of the problem
