Originally Posted by 1bad12v
i figured i do the repair with my mechanic/neighbor. just wondered what i be getting into time wise. but i have never timed an injection pump.......
There is a cap nut on the side of the injection pump, if you remove this nut there is an insert inside that when turned around is used to lock the pump in TDC. You must find TDC first though.
This will allow you to remove the pump without having to retime it as long as the engine isn't rotated while the pump is off.
It would be preferable to retime the pump to 15-16 though.
Instructions>
TSB 18-10-94 Rev. A
