2 blown head gaskets, oil in radiator! Help please! - Page 2 - Dodge Cummins Diesel Forum
post #13 of 35 (permalink) Old 01-26-2014, 03:23 PM Thread Starter
Team12v's Avatar
I'm thinkin it night be oil cooler for oil bein in radati but how would that give me blow by and sticky smelly oil.. blocks clean and not warped, studs are to spec
1998 12v 3500 dually, 4.10s/5speed, no fuel plate, A1 12m headstuds, Pheniox friction 10puck clutch, 5inch tip, AFC tuning stock timing, BHAF intake, Reman tranny, 235/85/16s 2 inch leveling kit.
Team12v is offline
post #14 of 35 (permalink) Old 01-26-2014, 03:29 PM Thread Starter
Team12v's Avatar
Im pretty sure its not my timing, the install went so smooth I read lots of fourms on how do it I think I did it right but just not have it I got in oil and in radiator! Im thinkin the oil in radatior is left over from the last head gasket failure when we did the radatior flush you could see the there was still oil in radatior its just at the top by the cap the overflow is clean antifreeze.. my main consern is this blowby and this sticky stinky oil.
Team12v is offline
post #15 of 35 (permalink) Old 01-26-2014, 06:20 PM
OK12V's Avatar
Every truck has blowby. Is yours out of specs? It will take few good antifreeze change outs before you get rid of the signs of oil . If your oil level is fine, drive it for awhile and drain coolant on nice and hot engine.
Never do more than one stupid thing at a time
OK12V is offline
post #16 of 35 (permalink) Old 01-27-2014, 10:28 AM Thread Starter
Team12v's Avatar
That's the weird thing, the oil level is fine its perfect on fill,the oil looks normal no green tint or anything just thick sticky and smelly.. alright ill do that
Team12v is offline
post #17 of 35 (permalink) Old 01-28-2014, 11:52 PM
did you mix 2 antifreezes together
cdmn196 is offline
post #18 of 35 (permalink) Old 01-29-2014, 12:24 AM
The Digital Bullet
Common's Avatar
What oil did you put in it?
TOTALED 3/23/16
| 1997 Ram SLT 4x4 | 3.55 | Dual Optima Red Tops | AFE Stage 1 | 5" Exhaust | MBRP 6" Tip | ARP Head Studs | TST #10 | 5 X 14 | 4K | 60LB | Air Dog 150 | ATS Aurora 3000 | South Bend 3600 | Auto Meter Pyrometer, Boost and Fuel Pressure Gauges | 20* | PEAK IC Boots |
FOR A QUICKER RESPONSE:
Common is offline
post #19 of 35 (permalink) Old 01-29-2014, 02:56 AM Thread Starter
Team12v's Avatar
No idea, there was so much oil in the radiator after the second HG failure and so cold I just brought it to Goodyear for a flush and they flushed it properly but either the oil in my radiator is left over or I have another blown head gasket but I really don't think its that... And I use mobil delvac 1300 super 15w 40 diesel oil from Wal-Mart been using it for years never failed me
Team12v is offline
post #20 of 35 (permalink) Old 01-29-2014, 03:08 AM Thread Starter
Team12v's Avatar
I'm gonna be home tomorrow ill warm it up good ill do a couple good flushes spend the day tryin to get all that oil out. change my oil and run it, ill let you guys know what happens!
Team12v is offline
post #21 of 35 (permalink) Old 01-29-2014, 09:12 AM
Dugan1's Avatar
I could be wrong, the "white" coming from your dipstick might be water vapor escaping.
crank case pressure will cause heat to anything. Pressure increase = temp increase. You might be some how steaming off moisture in the engine from the last HG. And the white is the water escaping and flashing to steam at atmospheric pressure. Water + oil looks white-ish/yoohoo colored.
Sorry for the engineering answer.. cant help what I am haha.
Dugan1 is offline
post #22 of 35 (permalink) Old 01-29-2014, 09:53 AM
Did you check to see if the block it self is not cracked, where it mates with the head? You mentioned antifreeze leaking around where the head mates with the block, hope this is not a case of "53 block".
98 Ram 3500(SRW Convert) 4x4 Quadcab,HP215 IP(15.5*,4K GSK,60lb springs),DAP 5x.016 SAC injectors,AFE Filter, BD Twin Turbos, 4" exhaust, gauges,47re stage 5 billit in/out shafts,dunrite VB,727DD pan,ATS 5-star TC,Borgeson gear box/shaft,3.54 gears.
FlaCracker is offline
post #23 of 35 (permalink) Old 01-29-2014, 10:16 AM
garagepeople's Avatar
Check to make sure the blowby vent is not plugged with white slime.
Before starting the engine i would crack the oil drain plug and see if water drips out.
If not warm the engine up, drain the oil and refill with new filter.
Use liquid dish washer soap and water to flush the cooling system.
flush with soap (running untill t-stat opens each time) flush at least 3 times.
Then flush with clean water 2 times.
You will need to fill with concentrate coolant due to the water that is held in the block.
Then reassess the blowby.
Remember a large vacuum leak can add to blowby.
07.5 QC/SB, 6.7, SB3250, G56 <delvac 50w> 4X4< nv271, 5inch SS silverline tbe, sinister egr delete, airaid intake, SJ67 on#1, ccv,gutted/rerouted ...smoke switch...
2009 VW jetta TDI 6speed manual. 96 ECLB 12valve auto/ats commander
garagepeople is offline
post #24 of 35 (permalink) Old 01-29-2014, 01:11 PM Thread Starter
Team12v's Avatar
Block is fine, not cracked nor warped. Ill have to check the. Blowby breather again but I don't think its clogged and just going to put it out there my oil is not "white sludge" the oil has its normal color.
Thanks for the lil radiator right up didn't know if I should run it with just water or not.
Team12v is offline
