my auto vs my manual - Page 5 - Dodge Cummins Diesel Forum
post #49 of 53 (permalink) Old 01-31-2014, 06:07 PM
country_hick's Avatar
Originally Posted by bootstrap View Post
I find that auto enthusiasts typically find any reason to bash 5 speeds.
Having towed the same trailer, same equipment with the same truck as an auto, and now a manual, this thing pulls way better.
If you keep the HP levels reasonable, and use it as designed, how often does anyone really have problems? After 5th gear is fixed, your usually all set.
Thats my feelings on the matter.
I chose an automatic because I have an issue clutching. I learned to drive using manual transmissions. Except for stop and go driving a stick is more precise and gives more control in most situations. However, in stop and go driving a stick sucks. I was caught in 4th of July traffic outside of Bar Harbor. It took me at least 1/2 hour to drive less than 5 miles perhaps it was 2 or less. I was seriously wondering if I was going to wear my clutch out that trip.
A friend of mine has a 460 ford 3/4 ton stick. Backing up a heavy trailer he smoked his clutch some trying to get the trailer into position. He never smokes his clutch normally but in tight quarters with a heavy trailer and a manual transmission it can happen.
Taking off with a heavy load in an automatic should use less clutch material compared to taking off with a manual. The automatic only slips its clutches when going into different gears. Using torque multiplication an automatic can take off when a stick would still be burning the clutch trying to take off.
GAmes has broken more NV4500 transmissions than most people will ever own. How about listening to a NV4500 breaker?
Nv4500/5600
Other than gear ratios, no. I removed my NV4500 for repairs 12 times in a 665k mile period and have put 300k on my G56 without a hiccup. Spending $3k for the conversion was worth it to me.
Nv4500/5600
The strongest transmission that Dodge hooks to a Cummins is the Aisin. The G56 is standard equipment in medium duty trucks in South America. The NV5600 to the best of my knowledge is only installed in Dodge 2500s and 3500s, both considered light duty trucks.
(Note: The aisin is the automatic)
Making the switch to nv4500(my auto is for sale)
All this talk about the NV4500 led me to chart out all the failures I had with mine. In 665,536 miles it was repaired or replaced 12 times. I had lost count, but I thought it was 7 or 8. The 5th gear nut fell off at 93,588. All the theories about the nut didn't apply to me either. I never lugged the engine and the biggest trailer I had ever hooked up weighed about 9000 pounds. While having the fully splined shaft installed they also replaced some worn parts and the next failure (not a 5th gear nut, BTW)
was 147,701 miles later. It was the longest period I ever achieved.
Rebuild again-55,851,
rebuild-7666,
rebuild-8601,
replace-56,961,
rebuild-47,181,
replace-29,311,
replace-99,120,
rebuild-7436,
replace-97,620,
replace-14,500.
Definitely sick of being broken down far from home I upgraded to the G56 when I had 65,000 miles on the last one. The upside is, I am positive that if the trans was an automatic, it would have failed more often and cost me more money.
(end GAmes quotes)
Although GAmes thinks an automatic would have broken more often and cost him more there is no evidence to support this idea I could find. Perhaps a built automatic would have lasted him 175,000 miles or more between rebuilds and been cheaper to rebuild compared to a NV4500. Sadly, we may never know unless we come across someone who has towed as GAmes does with a built automatic instead of a manual transmission.
Having said all of the above I honestly would have looked for a bought a 5 speed truck if my clutching was still smooth. However, a relatively minor physical issue can demand a change in what you need. Plus I was thinking about still driving the diesel I bought at age 70 or later. If I have bad shoulders or arm problems I can drive a lot easier without having to reach for a shifter all the time.
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
post #50 of 53 (permalink) Old 01-31-2014, 08:32 PM
Nv4500/5600
Nv4500/5600
rebuild-7666,
rebuild-8601,
replace-56,961,
rebuild-47,181,
replace-29,311,
replace-99,120,
rebuild-7436,
replace-97,620,
replace-14,500.
(end GAmes quotes)
That sums it up well. I actually prefer a stick over an auto. Always have. Just absolutely not an NV4500. When you experience a ZF6 (which I had in a 7.3 L F350), or a G56...true heavy duty manual transmissions, they are extremely reliable over the long haul with very heavy and frequent towing in all gears. Very different internals. In fact, the ZF6 and G56 are used in 26k GVWR commercial trucks and the installation used behind the 7.3L International motor I drove had a built in transmission cooler and pump right from the factory. If I was going to do a "manual swap" as everyone seems to mention I would do so with a trans worthy of the labor (as many in the know have done like GAmes).
Fast forward to current day with the interesting Aisin auto as mentioned above. You can only get the factory 850 LB max torque rating with the Aisin auto and if you chose a G56 manual that requires the pairing to a lower output 660 torque rating motor.
1996 2500 4x4 SLT Auto eclb, 3.55 LS, KDP killed, 94k miles - stock
1991 W250 LE Auto sclb, 3.07 LS, KDP killed, 285k miles - stock
1992 W350 LE Club Cab 5spd Getrag 366 spring - Sold
sootnsmoke is offline
post #51 of 53 (permalink) Old 01-31-2014, 08:50 PM
that's not due to a manual not being able to handle the power. if that was the case, semis would be automatics. however, they're not. the autoSHIFTS they put in them are junk and are not an actual automatic. pull a hill and they downshift. the manuals actually PULL the hills. the limitation is the transmission they're using. they don't see enough of a market to actually put a decent manual behind them. those of us who can actually shift a manual transmission is dwindling FAST.
2003 2500, 5.9 HO, little more then stock with lots to come
2007.5 2500, 6.7 liter cummins, Smarty S67, FPE Boost Controller, HE351VE w/ 60/83 comp wheel, Air Dog FP-150, 5" TBE SOLD
1995 Chevy w/t, 4.3l V-6, 5 speed manual sold
bloyet03 is offline
post #52 of 53 (permalink) Old 01-31-2014, 11:20 PM
alanack6795's Avatar
This sums up the auto/ manual debate
1994 2500SLT 4x4 Auto. Hewitt EGT, Boost, Trans gauges, Mech FP gauge, Trident fuel lines, Tork Tek OFV, Diamond eye 4" turbo back, 37337 Upgrade. 240K
98 12 valve 4x4 auto ECLB 4x4 "Basket Case" built trans, 3rd gen trac bar Needs: Injection pump, Injectors, Numerous oil leaks repaired.
alanack6795 is offline
The Following User Says Thank You to alanack6795 For This Useful Post:
ghostman (02-01-2014)
post #53 of 53 (permalink) Old 01-31-2014, 11:38 PM
Agreed. The demand for manuals is disappearing fast and kudos to RAM for being the remaining hold out to continue offering one. By interesting, I mean odd that they reserve the highest power level for an auto only. I don't think anyone would have immediate concerns about the G56 and 850 Lb Tq. At the same time, it is also noteworthy that the auto is likely very stout.
You are wrong about semis and auto. However, that is a mistaken belief that is very common. Sadly, traditional manual transmission gear boxes in big rigs are starting to go by the way side. For those interested in big rig auto transmission and AMT technology, here is a good read about that:
Auto vs. manual transmission: Data-driven tech better than complete control? | Overdrive - Owner Operators Trucking Magazine
Transmissions: Automating for Fuel Savings - Articles - Fuel Smarts - Articles - TruckingInfo.com
Lots of reasons why manual transmissions in big rigs are going away but most are centered around fuel efficiency, safety, city driving advantage, reduced driver skill required etc.
