My torque is slipping can i just install a performance convertor and this will fix the problem or will the tranny have to be overhauled the truck has about 300,000 km on it.
1996 3500 ext.cab 2wd,modified trans.&torque converter,HTB2 62/14 turbo,#10 fuel plate,4"exhaust,autometer pyro&boost gauges.
#2 (permalink) |
You can do that, but its kinda a bandaid for whats to come, you might just get away with a seal kit and converter, you should also do some pump mods too. I really like the TransGo kits for the Fords, it might work for you.
#3 (permalink) |
Where do you get these trans go kits you are talking about.
#4 (permalink) |
transgoperformance.com
94' 3500, 5sp., reg. cab, dually -Marine Injectors,#0 Plate,No Filter Or Piping,Side Shot Exaust,Schwitzer Turbo...95' 2500 Reg. Cab,Auto.,Single 8" Stack,Grinded Stock Plate To A TST Profile,Star Wheel 1 Full Turn Back From Max,No Filter Or Piping...
#5 (permalink) |
Suncoast also sells the Transgo kits. But I think a VB upgrade along with the convertor would be a better route myself.
http://img.photobucket.com/albums/v3...tinb4k/New.gif 1994 2500 Reg. Cab 4x4 SLT Laramie CTD/DTT 330hp/765trq - Work Truck 2002 Ford F150 Super Cab - Daily Driver |
#6 (permalink) |
Would i really need a valve body or could i just get by with the convertor i do not have alot of money to spend right now.
#7 (permalink) |
You could go with just the Trans-go shift kit and the convertor I guess. Not really something I would do or recommend as the Valve bodies do alot more to help with fluid flow thru out the trans. vs. the stock VB.
#8 (permalink) |
With 300,000 KM on the clock I would probably go thru the tranny. The input shaft probably has stress fractures on it also.
B&B performance: Industrial Injection, HTT, EDGE, Bully Dog, BD, South Bend Clutches |
