bought a truck got a deal on it but i can crank it up runs bout 15 seconds dies i can gas rag it or starter fluid dont like to and it and it will crank run fine dont take much to start it if i let it set and idle for awhile seems to white smoke a lil and loads up like something is hanging open mods are 150 injectors 4k gov springs hx40 turbo where should i start or what could it be i dont see any fuel leaks also it has 5 speed i have a 6 speed witch one is tuffer
My 12 valve would run for a few minutes then shut back off. I suspected the lift pump, and sure enough, the spring inside was broken, so the plunger wasn't contacting the cam anymore. I replaced it, and it runs perfectly. Not necessarily the cause of your problem, but it's worth a look. It could also be your overflow valve.
Gotcha what bout sometimes when I let it sit and idle for a lil while it will start to white smoke and act like its getting to much fuel till I clean it out then no white smoke
Mine just had same problem white smoking for me was due to feezing temps. But mine would not really run just for like 30 sec then die. I changed the return hose which had cracks in the end not sure if that was the problem. And also my prefilter o ring was shot so maybe sucking in air there and changed fuel filter no problems at all after 300 miles.
