Just picked it up tonight! 1995 completely stock. Needs a new dash and has a slight driveline shake from 35-50 needs to be worked out. Other than that, runs like a top!
That teuck reminds me of the first cummins truck I rode in. It looked exactly the same as that only on the top oc the hood towrd the front it said in big bold white letters "public access prohibited"
It was a cummins R and D truck. I loved that truck. My uncle is an enginner for Cummins and he would drive it quite a bit.
Yeah I'm gonna repair it to original and it will stay stock, for a little while lol. It is my dedicated DD right now since my other truck is down. I can't leave it stock forever, it can't hardly get out of its own way right now lol. It will get a little power bump and tranny upgrades.
Well figured out left front tire lipped a belt so need a new tire and put a new NAPA thermostat in it which helps, but it's still not getting all the way up to operating temp. Maybe I'll have to get a cummins t-stat.
I think I might see if a 6.7L 200* will fit in there.
Also just ordered diamond eye 4" dual exhaust from CPP. Black Friday sale. Can't beat the price on it. I don't think I could piece it together as cheap as it was.
On the thermostat issue, the napa one works alright, but hardly reaches 170* and lots of fluctuation, most of the time trucks running at 145* which is far to low for me. I ordered a thermostat for a big block 440 (part number 532090) that should fit and it's a 192* degree and supposedly designed to shorten warm up time, maintain consistent temp, etc. I'll try that stat next and see how it does, then if not I'll go to the cummins stat and try maybe putting a orifice in the coolant bypass.
My exhaust should be here Thursday or Friday so that will be going on along with a fuel filter change and oil change. Already changed the air filter. This truck is surprisingly very quiet in stock form. I'm going to bump the timing this weekend, I'm thinking 18* and do the typical AFC mods, grind a #10 plate, but still set it very conservative on the fuel since trans is still stock. Also, going to clean up a bit of the wiring mess under the hood.
Might even have time to troubleshoot the cruise control. Any typical problems with that to look for? Might also set valve lash if I get time, shouldn't take too long.
Well went to change the fuel filter tonight and I think I have found out that the lift pump is shot. Won't prime through the bleed screw and is leaking fuel out from around the primer button. Haven't got gauges in it yet so I don't even know FP. FP gauge should have come standard on these trucks.
Pretty darn sure I'm not getting any lockup either. I'll put a switch in and see what happens.
Stopped at the local Cummins store and picked up a new lift pump. This new lift pump looks much more robust, larger, and better quality. I will compare the two once I have them out.
I used a Cummins lift pump as well, and installed it with no studs. I had no problems whatsoever. I think it has to do with what position the cam is in.
Finally found the banjo bolt I was missing and got the rest of the fuel system put back together. This new fuel pump definitely primes the system much faster and it fired right up. This leads me to believe the old pump was definitely shot. Also installed a 192° thermostat so I will see how that works out. This four-inch dual exhaust kit isn't quite a bolt on kit like I was hoping for. It will take some modifications to the hangers and brackets to make it work correctly. It's not quite as simple as a single four-inch kit but it sounds sooo much better than the stock exhaust with muffler.
It has been 32° outside today with 20 mile-per-hour winds and now it is misting so I'm going inside for the time being.
New thermostat is much better! It's a Murray #15479. Also got the exhaust finished up. I think I'm gonna cut the end at and angle or parallel with the pinch weld and 2 1/2" out from the pinch weld. What y'all think?
Do you mean parallel or perpendicular? Parallel would be pointed straight back. In think perpendicular, with 2.5" past the pinch would look great :thumbsup:
I vote for parallel 2.5" out. Sticks out enough to hit on something or another as is.
