đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Hello Cummins friends, A little intro: I've had this truck for nine years and has been used primarily for daily driving and towing. Over the time of driving, it's developed a nasty oil leak from the tappet cover, and I finally decided to address it. The truck has had a long crank start for a...17 replies 309 views
In the morning when it's cold or wet out the wiper intermittent positions don't work at first but eventually start working once the truck warms up. The module plastic near the connector shows signs of melting but I think the module is working properly and maybe the connector pins are not making...3 replies 153 views
Been a while since I got the truck (see new member post from back in Oct) and had a chance to get on as it's been a crazy last few months. So far as you can see, I removed the decals, added Cruise Control (thank you YouTube) and installed a quadzilla XZT (mostly for the high idle but when...0 replies 12 views
