Old 08-16-2008, 03:58 PM   #1 (permalink)
96 Trannsmission Problems
I just picked up a 1996 12 valve 2wd automatic from another forum member and the tranny is having some problems. It has 300,000 original miles on the tranny and engine. The main problem is when it shifts into OD, if you let off the gas it drops down into 3rd, then when you get on it again it usually jumps back into OD or sometimes stays in 3rd. Also, sometimes it sticks in second and you have to slow down then accelerate again to get it into 3rd. It has enough fluid but the fluid is brown. I am assuming im going to need a rebuild, but before I do, is there any sensors I can check over first?
Also, anybody have any experience with this tranny, or any thoughts?
[ eBay Motors: 47RH Cummins Diesel Extreme Towing Transmission (item 170238026000 end time Sep-07-08 10:39:41 PDT)
(can't get the link to work so here is the auction #: 170238026000)
I know its not one of the "big" diesel tranny names but i really don't feel like dropping 4 thousand or whatever on a heavy duty tranny. Im just going to crank the pump and a set of small injectors. Not doing and racing or heavy towing.
thanks
2001 Dodge Ram 2500 Sport Package 6 speed AEM Brute Force Intake FBD 5" straight w/6" tip FBD 110hp injectors Fass 150/150 Pyro, boost, and fuel pressure gauge 2.5" leveling Kit 315/75/16 Dick Cepek FC II Adrenaline w/ Smoke Switch Valair Dual Disk
aschultz91 is offline   Reply With Quote
Old 08-16-2008, 05:13 PM   #2 (permalink)
youngcummins08's Avatar
i would first change the trany fluid and filter. any hook a scanner to it to see if it has any codes. btw, does it smell burnt? mine does the same shifting problem going from 2nd to 3rd sometimes, maybe it is just a dodge thing
my rig
96 2wd reg cab, 363k, K&N. Replacment airfilter, homemade 4in.
youngcummins08 is online now   Reply With Quote
Old 08-16-2008, 05:55 PM   #3 (permalink)
A 47RH won't work in a '96. It has a 47RE.
KDP tab fix info and fuel system article jgeorge1@suddenlink.net '95 2500 CC auto 4X4,3.54,Combo EGT/boost guage,PacBrake,TST #5,370 injectors,DTT TC/VB, Cummins chrome kit.
Joe G. is offline   Reply With Quote
Old 08-16-2008, 05:59 PM   #4 (permalink)
norwood dodge's Avatar
I would first check the throttle position sensor voltage with a digital volt meter. If it was faulty, the voltage would not be steady at a steady speed. Usually a 96-98 year model that hangs in second until you let off means that the inner lip seal in the direct drum is not sealing. The fluid will leak by and delay the shift into third. But with 300,000 miles, any thing is possible !
4.5 D3500 auto 4X4, Smarty Jr, van Aaken 3.1, Dipricol gauges, straight piped, silencer ring MIA,Stage II AFE w/ Amsoil nano-fiber filter, CFM+ and heater delete, Amsoil from end to end, Silver Bullet HD Trans w/ Billet converter !! 9/27/08 427hp and 815tq !!!
norwood dodge is offline   Reply With Quote
Old 08-16-2008, 08:37 PM   #5 (permalink)
yeah i put up a different listing by accident... Here would be the correct model
eBay Motors: 96-03 Dodge Cummins Diesel 2500 3500 47RE Transmission (item 150282020239 end time Aug-21-08 11:18:35 PDT)
(150282020239)
Any idea what the correct voltages should be?
And do you guys think it would really be worth changing the trannsmission fluid and filter?
It really doesn't smell burnt, but it does smell.... different
Old 10-01-2008, 02:18 PM   #6 (permalink)
Old_Red's Avatar
the correct voltage is .3 to about 1 volt with the key on engine off and throttle at idle. at Wide open it should be around 3.5.
Having the same problem with mine except its a constant 4.86. So im S.O.L. thePartsbin.com has them for about 55 bucks.
Old_Red is offline   Reply With Quote
Old 10-01-2008, 10:09 PM   #7 (permalink)
Call Fred West at F & S transmission. Tell him you got his name and number from the Cummins forum. His number is 303-995-0347. Fred knows the Dodge trannies inside and out.
He should be able to give you some advise.
1998 12V Quad Cab, LWB
“The more I search for my significance seems the more I disappear. I wonder have I made a difference in anybodies life since I’ve been here.” Randy Travis
rcsund is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
