Old 08-13-2008, 06:15 PM   #1 (permalink)
I.B. Cummin's Avatar
NORCAL Help!
Im lookin for someone to help or install some gov springs. Sac/Stockton area and know what your doing, i could use the help.
thanks all..
(looking 4 injectors) '98 12v 2wd 5sp man:#100 plate ff,4k gsk w/hd springs,aem HD,4"exh, ring-heat grid-cat-muff all gone, kdp tabed, etc. and an 04.5 HO qdcb(stock)
I.B. Cummin is offline   Reply With Quote
Old 08-13-2008, 09:59 PM   #2 (permalink)
There not that hard to do. i have some good directions if you want to try to do it yourself. it should take about a hour to do. Do you have the tools to do it ? mike
:06 5.9 3500 sg.rear wh. 6 speed 4 dr LB 4x4 red edge juice w/A2 HOT 1995 2500 4x4 5.9l auto, Head studs,60#v.s.,head ported. super b special,BD exh. man. ,75Hp. ddp inj, 4000 GSK,larger holders and lazer cut DV, 18.5* timming ,home ground 100 plate.
mike uz is offline   Reply With Quote
Old 08-13-2008, 11:09 PM   #3 (permalink)
they are simple to do but take your time and make good use of a magnet, dont want to drop anything.
'96 p-pumped 24v,too much done...engine build underway
02 psd stock 400.5hp 798tq
rol'n_coal 12v is offline   Reply With Quote
Old 08-13-2008, 11:45 PM   #4 (permalink)
i have plenty of tools but im not so mechanically inclined..
any instruction would be appreciated
Old 08-14-2008, 02:46 AM   #5 (permalink)
Tech Specialist
PDR Diesel Inc. The turbo diesel performance specialists! - 12V GSK
Go in from the side, and set the tension by the number of "clicks" initial + 3
I'd be down, but we are on different sides of norcal
98 Dodge 2500 Motor: 12 valve, BD exhaust brake, 4" turbo back exhaust, BHAF, KDP tabbed, 4K GSK, O-ringed head, .020 over HG, Modified AFC, DDP Stage 3 injectors, DDP DVs, 17.5* timing, 16cm^2 ex. housing Drivetrain: 5-speed 4x4 w/ SB clutch (13" OFE 450Hp)
Dual K20s is offline   Reply With Quote
Old 08-14-2008, 08:58 AM   #6 (permalink)
Diesel Nut Motorsports
Diesel Nut's Avatar
We are in Sacramento, give me a call if you need some help!
Diesel Nut Motorsports.com
Everything you need for your diesel. Performance, mileage or repairs, we have it!
1-800-450-7036
Our Amsoil webpage
Become an Amsoil Preferred Customer
Become an Amsoil Dealer
1990 Reg Cab - Project Truck
1991.5 Reg Cab - Parts Runner
2006 Quad Cab
Diesel Nut is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
