Old 08-11-2008, 10:49 PM   #1 (permalink)
pcm
i have a 97 cummins manual trans and a bad voltage regulator and i was told that it is in the pcm powertrain controll module if this is true how do u check it and what is the next step?
chinkboyus is offline   Reply With Quote
Old 08-12-2008, 08:55 AM   #2 (permalink)
clc
clc's Avatar
Try a search on "external voltage regulator".
http://www.cumminsforum.com/forum/search.php
You should find information and workarounds.
And,
96 3500 4WD, 47RE, gauges; 97 3500 4WD 47RE, gauges; 97 3500 2WD 5-spd; all club cab. 98.5 2500 2WD SB, 5-spd, gauges, quad cab
clc is offline   Reply With Quote
Old 08-12-2008, 09:44 AM   #3 (permalink)
Moderator
The stock alternator is made for an external regulator. The PCM is the regulator normally. The alternator does not care whether it is controlled by the PCM or a regulator. The PCM is not affected by not being hooked to the alternator.
Any 12 volt regulator will work.
Most two terminal regulators have the contacts in the shape of a pyramid. One terminal is missing. The missing terminal and one other terminal are at the base of the pyramid.
Hook the two alternator terminals to the two regulator terminals. Does not matter which goes to which. Disconnect the wires to the PCM and tape them. Now run a 12 volt line from an ignition source to the top regulator terminal along with the alternator wire. That's it except you need a good ground from the alternator to the regulator case.
If you hook the 12 volt up to the wrong regulator terminal, it does fry the regulator.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Both far from stock
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
