cant find TDC for timing!
attempting to do some homestyle pump timing (taking it to 15*)...but cant find TDC! the dang timing pin wont enguage and it doesnt seem to be bent like it got sheared off or anything. any advice guys?
3.55s, 305/70/16s, MBRP 4''Turbo Back, #100 Full Forward, AFE ProDry Stage 1, DDP3s, Boost Elbow, AFC !MIA Silencer Ring !MIA, 55 PSI, DiPricol Boost/Pyro/Trans, KDP Tabbed, Built 47re, Farmboys Full Cut DVs, 3k GSK, ATS Quikspool |
#2 (permalink) |
Moderator
Good thing the pin didn't work for you, I've found them to be as much as 3° off. Many others have had the same experence. Way I do it is to remove the #1 injector and use a magnetic base dial indicator to find the top of the piston stroke, mark dampener, rotate engine 180° mark again then divide the distance between the two. Others use the drop valve method. Find close to TDC by watching #6 valve until it's at crossover (one rocker going up, the other going down at the same time) Tighten down #1 exhaust and intake valves slowly rocking the engine back and forth slightly between tightenings. When you can't bar the engine over any more it's at right on TDC.
Bill '95 2500 4wd auto '95 3500 5 speed heavy hauler Both far from stock |
#3 (permalink) |
Assumings I look forward to getting possibly 50hp or 90hp injectors and get a 3GSK kit along with a Rack plug.this might be a good rule of thumb to remember for the things that I do have done to the truck already. Was really wondering if there was a rule of thumb of how much to move timing to. Like if you run nitrous on gassers. its like 2 degrees for every 50 shot of nitrous.. You hear some folks go to 15 degrees some 17 degrees with there injection pump..
1997 2500 4x4 ext cab, Apillar EGT, Boost Gagues #0 Ground fuel plate, Waste gate elbow, AFC forward, 3GSK, KDP repair, 15.5* timming, Custom air intake, 4" exhaust Straight pipe from down pipe back, Auto to NV4500 Converstion, Valair Clutch.
#4 (permalink) |
well even a stock truck will benefit mileage and power wise from advancing timing. apparently cummins designed the ISB for around 15* advance (??) but it was turned back due to smokeyness or california emissions or something? for you id run no more that 15.5* advance. thank you very much for the info illflem! ill have to see what i can do this weekend. but what do you mean by tightening down the valves?
#6 (permalink) |
thats what i was thinking. roger that. thank you again
