Oil Change
Ok, so I changed my oil for the first time yesterday. Other than the old filter apparently being torqued on with an impact, everything went well. Until... I went to put the drain plug back in and didn't even get it tightened up very much and the ring around the edge broke free of the screw part (sorry, don't know the official names). Luckily, O'Reillys was open and I was able to replace it. I guess I should have known something was wrong with it when I took it off...the flat part was bent outwards. Next up, fuel filter. |
#2 (permalink) |
That failure was probably caused by an old error in the owner's manual. It had the torque spec for the oil pan drain plug as 60 ft/lbs. Way too high. 25 is ok.
KDP tab fix info and fuel system article jgeorge1@suddenlink.net '95 2500 CC auto 4X4,3.54,Combo EGT/boost guage,PacBrake,TST #5,370 injectors,DTT TC/VB, Cummins chrome kit. |
#4 (permalink) | |
Cummins Diesel ADdict
under torque could cause the nut to spin off especially with the pressure that build s up in crankcase. JMO
2006 2500 QCLB 4x4 auto-5" SilverLine TBE - cfm plus- s&b CAI system- 6 inch superlift- kore components- 325/60/20 bfg AT's- 20" motometal- fs2500 on engine & tranny- maghytec all around- 4.10gears- edge juiced/w attitude- truckcoverusa roll out cover- rhino linings- firestone bags- Nfab 6step ![]() k7gsxr1000- full race bike- ohlins all around-brembo masters-full ti arata exh-pretty much everything |
#5 (permalink) |
It's not really. The problem with failing drain plugs was caused by the torque spec being too high. If you are going to tighten it with a torque wrench then about 25 is ok. No need to be any tighter. I don't use a torque wrench.
