👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Just put my first diesel motor in. 6.7 Cummins in a 2013 ram 2500. Doesn’t want to start seems like it’s not getting fuel but when it’s cranking and once in awhile when it starts shortly there’s a very loud banging seems to come from lower passenger side of motor. Also when the key is on but...3 replies 150 views
I have a 2006 Dodge Ram 2500, mega cab with 4 wheel drive and the 5.9 cummins. I am in need of tires here soon, as the tires that are currently on the truck are 13 years old and have a screw in two of the tires. No one will repair or rotate the tires because of their age and wear, so I am trying...50 replies 1K views
If your like me and had the code p04db come up after installing an AFE intake it annoyed me like crazy and being that I live in California it prevented me from getting a smog I sat the stock intake and the AFE intake side by side and went threw them both throughly and found out that the CCV...11 replies 3K views
Howdy folks, Can anyone get me started with a baseline rear caster setting on my truck? It's a 2018 2500 4X4 with a 4" lift. Looking at the position of the bolts, something is definitely off here. Rear passenger side of the truck sags an inch or two. With the steering wheel centered, the...10 replies 213 views
