Old 08-03-2008, 11:00 PM   #1 (permalink)
Questions on 96' 5.9l
Hey guys, i'm new here, and I am in the proccess of getting a 1996 5.9l cummins 2500. The truck is in really good cond., few rust spots here and there...but all in all good truck. The guy I am looking at buying it from says it has had no problems, its been stock its whole life, the only thing added was a stack. My question is, what do you think its worth? Its got 239,000 miles; how much longer should it go? I know the 5.9 can go over that easily...
Also, is there anything with this year I should be worried about? Lift pumps? etc. etc.
Thanks!
Soon to get...2008 2500 Cummins 6.7l Quadcab, shortbed, Bright Silver....STOCK
Mods I want to do:
- Edge Attitude w/ Monitor, 5" dual rears or 5" stacks with aussie tips?$:
Brewer711 is offline   Reply With Quote
Old 08-03-2008, 11:21 PM   #2 (permalink)
shelbuilt's Avatar
brakes lol they suck if it has a vacumm leak it all depend where your at in arizona ext or single cab two wheel like that will go from 4 to 8 4x4 5 to 10 in idaho those prices go to 7 to 12 and 8 to 16 dodges have little resale in az in idaho they love these trucks cold weather engines rock solid 4x4
93 dodge 97 motor ht3e mystery injectors???? nv5600 dana 80 dually rear end
built ceramic clutch: is trashed again!?!?
shelbuilt is offline   Reply With Quote
Old 08-04-2008, 02:18 PM   #3 (permalink)
thba2006's Avatar
Yeah, I'll attest 2nd gen brakes are horrid. Haha My lift pumps causes a ticking noise, but everthing I was told, it's common and not to worry bout it. All in all their good trucks, and you really shouldn't have much to worry bout, maybe injectors might need changed.
97' 2500 Cum D, 5 spd. manual 4X4, straight piped , MIA silencer ring, my fuel plate magically moved all the way forward, and the star screw spun it's self 10 clicks, Glow Shift Boost, Pyro, and FP Gauges and added tow mirrors.
thba2006 is offline   Reply With Quote
Old 08-06-2008, 01:36 PM   #4 (permalink)
UR FRIENDSHIP DUES R LATE
mattpopp's Avatar
I bought my 96 ext cab auto 4x4 larime 2500 134k miles on it for $8250 out the door. it was in pretty good shape, no mods, still had the stock exhaust on it. this was about four months ago in Houston.
The front end was wore, Replaced all of the Tie Rods with MOOG and the ball joints where in good shape. Put a new A/C compressor on it. That was the only concerns with it.
07.5 6.7l 2500 MegaCab 6sp Auto, 4x4 Inferno Red, Tough Country front Replacement, Browns Rear Replacement, NFab crappie 6 steps, Painted Pocket Flares, 20x10 4.56 backspacing Black Rockstars, 35" Toyo A/T's, 6" Superlift, Air Bags,
96' 2500 4wd, 47RE, Ext Cab,5" TBE,AFE Drop in, 134k ANTI-
Poor People have been voting for Democrats
for the last 50 years... and they are still poor.
mattpopp is offline   Reply With Quote
Old 08-06-2008, 02:01 PM   #5 (permalink)
Illinois Chapter Web Guy
4ropr's Avatar
Thumbs up
Up here in Illinois that same truck would cost you 11,000 if not more... you got a good steal...
'97 Ram 2500, Custom White Paint, Barbed Wire Pin Stripe, Decals Stripped, Ext. Cab, 4 X 4, 35" MasterCraft Courser A/T's, Any Road Any Time! Fuel Plate slid, Star Screw out.
http://www.myspace.com/illinoiscumminscrew
4ropr is offline   Reply With Quote
Old 08-13-2008, 01:59 PM   #6 (permalink)
I'm in IL, and the truck is 96' 5.9 w/ 239,000 miles. Has a plow, toolbox, back-rack, new tires, new brakes, etc. Is 4,500 a good price? seems to it to me, but I'm just not sure with 239,000 how the drivetrain will hold; tierods, balljoints, cvs, etc. etc. etc.
Mods I want to do:
Old 08-13-2008, 11:15 PM   #7 (permalink)
ball joints brakes and track bar is what i had to replace on mine along with a head gasket i paid 5000 in idaho for a single cab 4x4 with 200000 on it 4500 sounds like a good deal 2 or 4wd
'96 p-pumped 24v,too much done...engine build underway
02 psd stock 400.5hp 798tq
rol'n_coal 12v is offline   Reply With Quote
Old 08-14-2008, 05:44 PM   #8 (permalink)
jcarl735's Avatar
steering is always loose. brakes arent the greatest hahahaha and the wheel bearings arent the strongest and kinda suck to replace as well as ball joints.
3.55s, 305/70/16s, MBRP 4''Turbo Back, #100 Full Forward, AFE ProDry Stage 1, DDP3s, Boost Elbow, AFC !MIA Silencer Ring !MIA, 55 PSI, DiPricol Boost/Pyro/Trans, KDP Tabbed, Built 47re, Farmboys Full Cut DVs, 3k GSK, ATS Quikspool
jcarl735 is offline   Reply With Quote
Old 08-14-2008, 06:12 PM   #9 (permalink)
who on earth are you guys buying trucks from that they are so expensive? dealerships? i've seen a few 96 auto 3500's with under 100K miles in perfect running condition for 7 to9 grand for sale in ohio where i'm at.
pikeman16 is offline   Reply With Quote
Old 08-14-2008, 06:44 PM   #10 (permalink)
5.9 guy's Avatar
I'm from michigan but a buddie of mine form michigan drove out to pennsylvania and picked up a 96 ctd 4x4 200000 for 6000 perfect condition.
02 2500 extended cab edge comp/drag box, K&N intake, 4 in MBRP exhaust, built trans, billet converter,HTS valvebody, autometer guages (trans temp, boost, egt, fuel press) bd frame mount lift pump, silencer ring moved out , lock-up switch
5.9 guy is offline   Reply With Quote
Old 08-15-2008, 11:23 AM   #11 (permalink)
rol'n_coal 12v ball joints brakes and track bar is what i had to replace on mine along with a head gasket i paid 5000 in idaho for a single cab 4x4 with 200000 on it 4500 sounds like a good deal 2 or 4wd
-- It's 4wd.
Mods I want to do:
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
