Took my tps off today to adjust it and things did not go as easily as expected.
Before removing the TPS the voltage read .1 at the idle position, after enlarging the holes and adjusting I was only able to get .4 volts
The voltage is still way too low, and I am stumped at how to achieve the recommended 1.2-1.4 volts...:confused013:
The bracket to throttle measurement is the required 5 inches... which is the only other measurement that I believe can affect things.
So do I modify the mounting holes on the TPS further? Or is my TPS just junk and that's why it is reading so low?
A picture of a modified TPS would be helpful. Thanks
