đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
I’m get super gnarly blow by but sometimes it’s not that bad. Motor still runs strong so I don’t think it rings. Maybe it’s a leaky injector o ring? Is it possible to have a bad turbo seal push air in through the oil drain?23 replies 368 views
Truck is a new-to-me 2007 5.9 2WD with 138k miles. The PO provided a stack of service records, for one of which they brought into the shop at 135,384 miles. The shop replaced the lower ball joints and sway-bar end links, and also advised: "rack & pinion has play in sockets and starting to show...12 replies 132 views
I installed a Derale cooler with fan awhile back and just now got around to wiring the fan. Ran the wire to the front of the truck in the same tubing that my Fass runs through. Question is can I plug the wire into one of the unused relay terminals that come on with the key and use an inline...6 replies 133 views
Hey guys, this is my first post so hopefully I'm approaching this right. Today I took my (new to me) truck through an automatic car wash (probably my first mistake) and the check engine light turned on in the middle of it. I'm assuming the undercarriage wash hit something and caused all these...2 replies 94 views
I'm thinking of looking for a decent flatbed to put on my 97 2500 SRW. When looking at a used one, without knowing what truck it came off of, how can I know if it will bolt on to my truck? Thanks for any advice you could throw at me.1 reply 70 views
