👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Any advice on what setting I can set and forgot for my 05 that hauls about 2,000 lbs in the bed and occasionally tow 5-7k. This truck is primarily hauling the 2k load up steep logging roads at 6-7000 ft elevation, so engine heat is a big consideration, especially since I have dual electric...10 replies 303 views
I have a edge comp box for a 2000 Dodge Ram 2500. I do not have a wiring harness for it and I contacted edge trying to order a new harness, which I was told they don’t make anymore since my tuner is manufactured in 2005. Will a newer harness work, or if someone could help me find a new harness...10 replies 3K views
Trying to fine-tune my alignment now that I’m on my new tires, stock 265/70/17. it feels like it kind of wanders at high speeds. I’ve got some angle iron I’m gonna make brackets to do good measurements, I’ll take the front wheels off and bolt the brackets to the hubs. Should I do zero, dead...6 replies 137 views
My truck was a factory Auto swapped to 5 speed trans. So I have found some auto trans remnants, but I don't know if this is one or what it is? Anyone know? 1 pic shows where hoses connect to the other shows the ends that were cut off.0 replies 21 views
