đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
If your like me and had the code p04db come up after installing an AFE intake it annoyed me like crazy and being that I live in California it prevented me from getting a smog I sat the stock intake and the AFE intake side by side and went threw them both throughly and found out that the CCV...11 replies 3K views
Howdy folks, Can anyone get me started with a baseline rear caster setting on my truck? It's a 2018 2500 4X4 with a 4" lift. Looking at the position of the bolts, something is definitely off here. Rear passenger side of the truck sags an inch or two. With the steering wheel centered, the...10 replies 203 views
I have a 2005 Dodge Ram 2500, 4x4, QC, Auto (Rebuilt Stage I), DPC Billet Triple Disc w/1700rpm stall speed, 4.10 gears, Smarty Jr, Banks Techni-Cooler system, SB Cold Air Intake, ATS Exhaust Manifold, MBRP Pro series exhaust, running 37x12.5-20. The truck has about 230,000 mi, it is mostly a...6 replies 248 views
Hey Cummins fam! Compounds or big single turbo for our 6.7s – what's your pick? Let's dive in and hear your thoughts! Discussion: Compounds: Efficient but complex. How's your setup perform? Share your experience. Big Single: Simple, raw power. How does it compare? Share your setup and...1 reply 114 views
