đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Truck is a new-to-me 2007 5.9 2WD with 138k miles. The PO provided a stack of service records, for one of which they brought into the shop at 135,384 miles. The shop replaced the lower ball joints and sway-bar end links, and also advised: "rack & pinion has play in sockets and starting to show...10 replies 116 views
Howdy folks it’s been a while since I’ve posted, I’m curious how much should a transmission rebuild cost in 2024, as well as having a transfer case resealed. I’m out west here in the pnw specifically Oregon.13 replies 237 views
Hi, I got a message “Service DEF System see dealer, speed reduced to 5 mph after 150 miles“. It also had codes P2509 (ECM POWER INPUT SIGNAL INTERMITTENT) and P20E8 ( RELUCTANT PRESSURE TOO LOW) Took it to dealer today and they said they checked system and just did a software update. I picked it...1 reply 9 views
Trying to fine-tune my alignment now that I’m on my new tires, stock 265/70/17. it feels like it kind of wanders at high speeds. I’ve got some angle iron I’m gonna make brackets to do good measurements, I’ll take the front wheels off and bolt the brackets to the hubs. Should I do zero, dead...7 replies 140 views
My truck was a factory Auto swapped to 5 speed trans. So I have found some auto trans remnants, but I don't know if this is one or what it is? Anyone know? 1 pic shows where hoses connect to the other shows the ends that were cut off.1 reply 38 views
