👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
I have a 2005 Dodge Ram 2500, 4x4, QC, Auto (Rebuilt Stage I), DPC Billet Triple Disc w/1700rpm stall speed, 4.10 gears, Smarty Jr, Banks Techni-Cooler system, SB Cold Air Intake, ATS Exhaust Manifold, MBRP Pro series exhaust, running 37x12.5-20. The truck has about 230,000 mi, it is mostly a...6 replies 248 views
Hey Cummins fam! Compounds or big single turbo for our 6.7s – what's your pick? Let's dive in and hear your thoughts! Discussion: Compounds: Efficient but complex. How's your setup perform? Share your experience. Big Single: Simple, raw power. How does it compare? Share your setup and...1 reply 114 views
Trying to fine-tune my alignment now that I’m on my new tires, stock 265/70/17. it feels like it kind of wanders at high speeds. I’ve got some angle iron I’m gonna make brackets to do good measurements, I’ll take the front wheels off and bolt the brackets to the hubs. Should I do zero, dead...8 replies 143 views
I'm going to start this thread again and hopefully it won't go off the rails and get closed. Installed new hubs. Amazing, the truck tracks straight down the road now and doesn't have an annoying click in the steering wheel anymore. Also installed the replacement drag link tie rod since I...8K replies 727K views
