Old 07-15-2008, 06:50 PM   #1 (permalink)
Possible ddp4 problem
I installed my ddp4s. easy install took my time extra clean yada yada yada, i idled my injectors for a while everything seemed good, took it for a test ride 1mile total. got on it awesome came back parked checked for leaks while still running, no leaks good, well i was staring at my engine and it would shake a lil every so often in a definate pattern like a slightly loose line for like a two secs and then back to normal. so i checked all rpms and its the worst between 1000-1250 rpm it seems to wave in and out its fine from 1250 up what gives
TIA
Casey
97, 2500 4x4 225k,5" stacks,KDP behind bars, BD tc, BD vb, 100 plate FF, 16.5, 4K GSK, 60lb springs, mack rack plug, afc springs, gauged, ATS exh, K&N w/tube, HTT 62/71/14 and DDP4s
shell 96 is offline   Reply With Quote
Old 07-15-2008, 08:09 PM   #2 (permalink)
ive been thinking, ddps are supposed to be a little more touchy right? so what if the problem is my 4kgsk i installed at the same time as my old low quality injectors?
Old 07-16-2008, 06:07 AM   #3 (permalink)
update
problem only occurs when its cold once it hits 140 or so it starts.
Casey
Old 07-16-2008, 06:10 AM   #4 (permalink)
i meant only when engine is warm
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
