Old 07-11-2008, 05:35 PM   #1 (permalink)
firedawg015's Avatar
Need help with a code
The check engine light has not come on, but my truck seems to run crappy when its really humid out - dies alot when idling, backing up at an idle, or pulling up to a stop sign. I decided to check for codes just out of curiosity and I got code 355. I checked the list in the tech articles and it said #5 ignition coil??? Anybody know what this means?
Firedawg015
'97 2500 4x4 xtra-cab 8' bed, Smoke screw cranked, plate full forward, BHAF, silencer ring MIA, straight pipe, wheels and tires.
firedawg015 is offline   Reply With Quote
Old 07-11-2008, 07:24 PM   #2 (permalink)
AlGores worst nightmare
Racer9's Avatar
Not seeing that number here Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
How did you get it?
'96 CTD, 4X4 flatbed, Isspro gauges, Skyjacker D-25's, ThurenFab track bar, lockRite.
Motor; BHAF, #100 fuel plate, Shimmed gov springs, Loose starwheel.
Exhaust; 16cm housing, 4" downpipe, 5" turnout stacks.
Trans; Dunrite VB/TC, Intelligent Engineering billet input shaft, Burt Brown rebuild/upgrade.
Racer9 is offline   Reply With Quote
Old 07-11-2008, 07:51 PM   #3 (permalink)
I cycled the key on and off 3 times. After this the light went off for a moment then came on and flashed 3 times then 5 times then 5 times again with a pause in between each time.
Firedawg015
Old 07-11-2008, 08:20 PM   #4 (permalink)
Bump, bump....
Firedawg015
Old 07-12-2008, 09:14 AM   #5 (permalink)
Moderator
Could be wrong but thought that codes with the key off/on trick were two digit numbers.
Know that 55 means end of test.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Both far from stock
Old 07-12-2008, 09:19 AM   #6 (permalink)
I wondered if it may mean something like that since the light hasn't actually been coming on. I remember a car that I had one time that blinked 3 times at the beginning to indicate start of test.
So does anyone else have any problems with their engine running bad on really humid days? Seems to be that's the only time it does it. Never had a problem on cool days or during the winter.
Firedawg015
Old 07-12-2008, 03:15 PM   #7 (permalink)
Racer9's Avatar
Read this; 94 Diesel Ram DTC's proper way to do the key on-off.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
