Old 07-07-2008, 07:41 AM   #1 (permalink)
NSJ15332's Avatar
help! truck no fire
it started up and I hitched up the trailer. went to start it again and it cranks but wont turn over. fuel filter was changed last month, tried priming it and still nothing. what would the problem be?
97 DODGE 2500 CTD Auto
5 inch stacks
NSJ15332 is offline   Reply With Quote
Old 07-07-2008, 07:52 AM   #2 (permalink)
Super Administrator
BBRam's Avatar
Is the primer actually moving fuel?
03-3500, DRW, QC, 4x4, DTT Trans, Mag-Hytec, R700 BD Twins, BD IC Boots, BD Billet Flexplate, Lockup Switch, SMARTY TNT-R BETA/TS MP-8, Eliminator Fuel System, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. Old #'s (R/T .021, 60' 1.76, 1/4 ET 13.14 @ 100.45 mph)
Old 07-07-2008, 08:22 AM   #3 (permalink)
NSJ15332's Avatar
it didnt sound like it was
5 inch stacks
Old 07-07-2008, 08:32 AM   #4 (permalink)
Super Administrator
BBRam's Avatar
I've only messed with these a little, hopefully someone will help out here if I'm wrong.
The truck will turn over, just not fire?
Do you have fuel to the injectors?
Old 07-07-2008, 09:03 AM   #5 (permalink)
proffesional bs'r
plowboy1138's Avatar
try crackin the injectors then turning it over the truck could b vapor locked
andrew stein, 92 D350 47rhauto banks flexplate, gorend tc, transgo kit drw pyro&boost gauge 40+boshe injectors fuel pin ground and turned with the smoke screw turned all the way in full power screw, holset hx40 WHEN I GROW UP I WANNA B JUST LIKE BEER PLAY
plowboy1138 is offline   Reply With Quote
Old 07-09-2008, 11:05 AM   #6 (permalink)
The first thing to check is to see if the fuel solenoid is pulling up. Read this: Joe G's fuel system writeup
KDP tab fix info and fuel system article jgeorge1@suddenlink.net '95 2500 CC auto 4X4,3.54,Combo EGT/boost guage,PacBrake,TST #5,370 injectors,DTT TC/VB, Cummins chrome kit.
Joe G. is offline   Reply With Quote
Old 07-11-2008, 10:20 AM   #7 (permalink)
pborger's Avatar
check to see if the shutdown solenoid is working try turning the key to the on postion but don't start it,pull the solenoid up to the magnet,if it sticks repeat them steps twice then try starting it
94 4x4 5sp 222000 autometer phantom gauges k&n air intake banks big head wastegate boost elbow afc spring kit kdp tap 300 injectors #100 fuel plate slid all the way forward 37psi Mac Plug
pborger is offline   Reply With Quote
Old 07-11-2008, 11:11 AM   #8 (permalink)
Post Solenoid...
Turn on the Key, Pull up on the Fuel Shutdown Solenoid till it "locks" then try to start the truck without turning off the key.
I have been doing this for about a week until I found the loose connection.
And the NUT behind the wheel
corbinstein is offline   Reply With Quote
Old 07-13-2008, 09:43 PM   #9 (permalink)
i actually just had the same problem mine was the shutdown solenoid its a pretty easy fix
cummins916 is offline   Reply With Quote
Old 07-14-2008, 02:54 PM   #10 (permalink)
pborger's Avatar
that is a common problem get a new soleniod and relay that should fix your problem City Diesel - Diesel Performance they have what you want
Old 07-15-2008, 08:20 AM   #11 (permalink)
cowboys toys's Avatar
I would have to agree with them the fuel soleniod would do that same thing happened in a buddies truck
FOR SALE 97 dodge ctd with loadstop exchange, govenor spring kit 4k, valve springs #60, 375 marine inj., laser cut delivery valves, 5spd, haisley double disc street puller clutch, bigger turbo, afe air filter, 5" stacks, pyro, boost, tranny temp guages
cowboys toys is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
