Old 07-06-2008, 09:56 PM   #1 (permalink)
smokeblack's Avatar
Compression
I have a 95 12 valve and I am about to do a compression test on it but i cant find the specifications anywhere. What should the compression be new and with almost 200k on her?
95 blue standard cab long bed cummins 5" exhaust with aero turbine no fuel plate HTT pro street 66 custom intake sbc laser cut dvs ddp4 140 horse nozzles 16* timing 4k gsk 60 lb. valve springs ATS built nv 4500 with 1 3/8 input shaft
smokeblack is offline   Reply With Quote
Old 07-07-2008, 12:09 AM   #2 (permalink)
cursedtofirst45's Avatar
new should be about 17.5:1 i believe
1997 Dodge 2500 Cummins/Nv4500
Lots of Fuel, Less Air.
cursedtofirst45 is online now   Reply With Quote
Old 07-07-2008, 02:49 PM   #3 (permalink)
smokeblack's Avatar
I was actually wondering the psi value sorry i didnt clarify
Old 07-08-2008, 12:07 AM   #4 (permalink)
ykdave's Avatar
Compression ratio is 17.9:1, but like you know, thats not going to do you any good.
Your looking for 350psi on a new rebuild, around 300psi on a good used engine and oddly enough you are allowed up to a 100psi variance between cylinders.
Best bet is a blowby test though...
97 Ram 2500 / 5.9ctd / 5spd / nv4500 / 4x4 / np241
Starwheel cranked, no plate, autometer pyro and boost gauges, Single 4" stack, 33x10.5 Mud terrains, tons more to come
ykdave is online now   Reply With Quote
Old 07-10-2008, 07:19 AM   #5 (permalink)
Charlie.Smith's Avatar
By "blowby test" you probably mean a leakdown test.
[ OOPS! ykdave corrected me. ]
A leakdown test will detect and pinpoint problems you'll never notice with a compression test.
As a humerous note, my leakdown tester is so old, it's got a plate on the body that says "Caution - stand clear of the prop" :-)
Charlie Smith - Columbus, Ohio
'97 2500 4x4 auto, Suncoast TC/VB, #5 16.5*, Arrowcraft DRW, Aerotanks D60, KDP
'96 3500 2x4 auto, Goerend TC/VB, #5 16* DDP2 355hp/970tq, D60 tank, KDP
Charlie.Smith is offline   Reply With Quote
Old 07-10-2008, 08:06 AM   #6 (permalink)
ykdave's Avatar
No, blowby test. Measuring the ammount of gasses that pass by the rings while its running.
Though a leakdown test is another alternative to diagnosing the problem area if you have low compression.
I can get you some more info on the blowby test if you need it, search on here and you can find info on how to build a cheap test tool instead of buying the one from cummins.
9 in/hg for new/rebuild (.221 orifice)
34 in/hg is max allowable (.221 orifice)
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
