Old 07-02-2008, 06:52 PM   #13 (permalink)
Originally Posted by jcarl735 View Post
oops on the first part! sorry about that. anywho i do have billet shafts in the trans. still probably not a good idea to shift when locked up huh? well anyway can you lock up the convertor in 2nd as well as 3rd and 4th?
If you have a billet input shaft then shifting with the converter locked is not supposed to damage it. If you have a manual switch you should be able to lock the converter in any gear but 1st.
mondtster is offline   Reply With Quote
Old 07-02-2008, 07:38 PM   #14 (permalink)
jcarl735's Avatar
sweet thank you. i might try it once, but i dunno if i feel like risking anything even with the billet. thanks again man!
3.55s, 305/70/16s, MBRP 4''Turbo Back, #100 Full Forward, AFE ProDry Stage 1, DDP3s, Boost Elbow, AFC !MIA Silencer Ring !MIA, 55 PSI, DiPricol Boost/Pyro/Trans, KDP Tabbed, Built 47re, Farmboys Full Cut DVs, 3k GSK, ATS Quikspool
jcarl735 is offline   Reply With Quote
Old 07-02-2008, 07:39 PM   #15 (permalink)
Originally Posted by jspike91 View Post
It will take off in 1st, then shift very quickly to 2nd, and on through to OD. and i can manually shift it down. however, it will not shift from overdrive in to drive when i press the button, i have to wait until i get slow enough to pull it down into 2nd before it will do anything.. earlier i put it in neutral coasting to a stop sign, pulled it into drive and it choked the truck down because it was in either drive or od sitting still....
I'd pull the valve body out and clean it. It sounds like there is either some dirt causing a valve to stick or possibly a solenoid going bad...
Old 07-03-2008, 06:46 AM   #16 (permalink)
jspike91's Avatar
I ended up taking the truck to a trans shop yesterday, and i hope i get the same answer from them, that is also what i was kinda thinking and im hopin it will be a lesser expensive fix.
thanx for the help, i will post up when i get some sort of solution
97 3500 4wd 4" tbe w/muf. delete, aem brute force, fuel plate and star wheel adjustments, wastegate blocked off, silencer mia, boost and egt guages
03 3500 2wd 4" mbrp tbe w/muffler delete,k+n fipk, silencer mia, edge juice hot
jspike91 is offline   Reply With Quote
Old 07-04-2008, 09:06 AM   #17 (permalink)
12valveterror's Avatar
i can lock up in any gear including 1st as well
97' 2500,12V,AT,4x4,230K MILES, DUNRITE TRIPLE DISC & V/B, BILSTEIN 5100's, DSS STABILZER, DIPRICOL GAUGES, BHAF, BOOST ELBOW, #0 FUEL PLATE, KDP KILLED, T/C LOCKUP SWITCH, 15* TIMING, 2" LEVELING KIT, 4" TURBO BACK TO 5" MITRES
12valveterror is offline   Reply With Quote
Old 07-05-2008, 07:58 PM   #18 (permalink)
Some valve bodies will allow for lockup in first and some won't. It depends on what you've got...
Old 07-06-2008, 11:49 AM   #19 (permalink)
jcarl735's Avatar
my truck also turns out to be of the special build period where i have to reflash the PCM for the lockup to work properly. so that gets done this week
Old 07-07-2008, 06:42 AM   #20 (permalink)
jspike91's Avatar
so the trans shop called and he says that the trans needs to be gone through and he is going to put in a heavy duty tq converter...$1400.00....
this is a very reputable shop.... he did a friends 01 2500, and has done several gas powered trucks and cars for me...
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
