Go Back   Dodge Cummins Diesel Forum > Speciality Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 06-26-2008, 10:57 PM   #1 (permalink)
Anti-freeze choices, additive ???
What anti-freeze's already have the additive so I don't have to mess with test strips?
I've got 1 pint of the Motorcraft additive, how many does it usually take when changing anti-freeze to get the proper mix?
'96 3500 Ext-Cab Dually, 2WD, 5-spd, 370's, #8 plate, Southbend Con OFE, 4" turbo back exhaust, BHAF, 3.54's, 235/85/16's, 110K miles
Green_Sled is offline   Reply With Quote
Old 06-28-2008, 11:28 AM   #2 (permalink)
any input ?
Old 06-28-2008, 12:40 PM   #3 (permalink)
Moderator
Most folks don't use additive.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Both far from stock
Old 06-28-2008, 03:14 PM   #4 (permalink)
That might be why my 97 has a crack internal in the water jacket. Between the oil passage and the coolant jacket.
Pumping oil into the radiator! Water drains into the oil pan down to level where the crack is.
Not the head gasket. Cummins store installed new hg and new oil cooler. They said it has a internal crack!
I removed the head, plugged the oil passages to the rockers. Jacked the rear end up so the engine block was level, filled water jacket level with the deck. Blew air pressure into the front oil passage for the # 1 rocker arm. Bubbles come uo from the water!
No one has ever heard of this situation before. I think the cummins store is protective of their product and are not saying any more than they need to.
Why would this happen to a one owner well maintained truck with 297K and then all of a sudden this shows up?
Electrolsis maybe?
Tom
gozapper is offline   Reply With Quote
Old 06-28-2008, 03:25 PM   #5 (permalink)
BILLS06's Avatar
If you already flushed the coolant system and changed the anti freeze, you won't have to worry about additive for at least 30k or 2 years
06 QCSB Airaid Baffle Delete MagHytec Transmission Pan Aeroturbine Muffler Fluidampr HTB2 Turbo Recon 3rd Brake Light Superchips Pyro/Boost & Autometer Ultra Lite Digital Oil Pressure & Transmission Temp Gauges ATS Exhaust Manifold & 5 Star TC Flexpiped CAT DDR Enabled Royal Purpled EZ Down Weston Nerf Bars Spray In Bed Liner Valley Gooseneck Hitch
http://www.myspace.com/montanadodge
BILLS06 is offline   Reply With Quote
Old 06-28-2008, 11:13 PM   #6 (permalink)
Running coolant without the additive will in time cause pin-holes in the cylinder sleeves in a diesel engine, its called cylinder wall cavitation or liner pitting. Regular anti-freeze does not have all the stuff in it needed to prevent cavitation in diesels, you have to buy an off the shelf additive like the Motorcraft or Fleetguard stuff and use test strips to check for proper charge. Some high-end diesel anti-freeze has the additive already in it.
Witnessed a cylinder sleeve pulled from a tractor the other day that was all pitted and full of pin holes from cavitation, so I'm looking to get my coolant in order in both my trucks soon.
Old 06-29-2008, 03:54 AM   #7 (permalink)
Moderator
From Cummins Service Bulletin 3666132-01:
"The B Series engine normally does not require SCA because the engine normally does not experience cast-iron cavitation corrosion. "
More here CumminsDatabase.com :: Anti-Freeze Replacement
Bill
'95 2500 4wd auto
Both far from stock
Old 06-29-2008, 07:17 AM   #8 (permalink)
BILLS06's Avatar
The test strips tell you if you the coolant is fine, need to add any additive, or the system needs flushed. And yes these engines are not Intertrashanals.
Old 06-29-2008, 07:46 AM   #9 (permalink)
strai8up's Avatar
you only need the strips if you are not running an ELC ( extended life coolant) most of the elc are red or orange in color. the green coolant usually needs the additive.
2005 SLT 2500 Hypertech max energy,southbend clutch ofe, b&w turnover ball
strai8up is offline   Reply With Quote
Old 06-29-2008, 02:27 PM   #10 (permalink)
For me additive is very cheap insurance
97 2500 CC LB 4X4 Auto 3.54 215 injectors 4" exhaust 144k
shorthair is offline   Reply With Quote
Old 06-29-2008, 11:34 PM   #11 (permalink)
i saw some "fleetcharge" locally that says "sca precharged"
is this what every one is discussing? or is there an additive on top of that?
1970 300 SEL is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
