Old 06-26-2008, 02:38 PM   #1 (permalink)
oil pressure sending unit part number
Does anyone have a part number for a 98 12v oil pressure sending unit? I have been to 2 different places. One does not carry it and one gave me the wrong part, had a different connector.
I could use the part number for both cummins and napa.
1998 12V Quad Cab, LWB
“The more I search for my significance seems the more I disappear. I wonder have I made a difference in anybodies life since I’ve been here.” Randy Travis
rcsund is offline   Reply With Quote
Old 06-26-2008, 05:03 PM   #2 (permalink)
AlGores worst nightmare
Racer9's Avatar
All your part #'s 96-98 engine specs just scroll down.
'96 CTD, 4X4 flatbed, Isspro gauges, Skyjacker D-25's, ThurenFab track bar, lockRite.
Motor; BHAF, #100 fuel plate, Shimmed gov springs, Loose starwheel.
Exhaust; 16cm housing, 4" downpipe, 5" turnout stacks.
Trans; Dunrite VB/TC, Intelligent Engineering billet input shaft, Burt Brown rebuild/upgrade.
Racer9 is offline   Reply With Quote
Old 06-27-2008, 09:31 PM   #3 (permalink)
Any ideas as to why the sending units I get from parts stores do not match the OEM unit that is on the truck?
Old 06-27-2008, 10:34 PM   #4 (permalink)
Tech Specialist
I bought one a while back and had the same issue as you. I was told that there is two styles of connectors a long and a short (it would appear my truck has the long and I was given a short) The replacement that I got wouldn't even connect to my stock connector. Does yours?
98 Dodge 2500 Motor: 12 valve, BD exhaust brake, 4" turbo back exhaust, BHAF, KDP tabbed, 4K GSK, O-ringed head, .020 over HG, Modified AFC, DDP Stage 3 injectors, DDP DVs, 17.5* timing, 16cm^2 ex. housing Drivetrain: 5-speed 4x4 w/ SB clutch (13" OFE 450Hp)
Dual K20s is offline   Reply With Quote
Old 06-27-2008, 10:54 PM   #5 (permalink)
Evidently I got the long on my truck. The one they keep giving me is the short so the prongs on it do not fit my connector. Where do you get the other?
Old 06-27-2008, 11:40 PM   #6 (permalink)
Tech Specialist
I haven't been able to find the correct sensor yet, I just deal with the occasional ding when it comes back to idle in warm weather
Sounds like we are in the same boat. I was hoping someone would jump on here and help us out....
I also wonder if the 98's use the same one as the 24 valves?
Old 06-27-2008, 11:48 PM   #7 (permalink)
I looked at a 24V at the parts store and it looked nothing like the one we have. I may go to Rocky mountain cummins in the morning and check on the part. I may also check into getting a new connector and use the more popular short version. I will let you know what I find out.
Old 06-28-2008, 09:27 AM   #8 (permalink)
For those of us that are cursed with the long sending unit the proper mopar part number is
56031005
This unit is 48.25 at the dealership. The Dodge dealership would not give me the number, I had to buy the unit which I will return on Monday.
If you take this Mopar number the local parts house can do a cross and actually find the proper unit. They do not have the unit listed in systems as belonging to our truck, just as a generic Mopar part number. After buying the unit from Dodge I went across the street to Advanced and got a unit for 26.00. The number for Advanced part was S4195.
Hope this helps.
According to my avatar I just made Cummins Fanatic. Do I get a cup of coffee or something. I would like to thank my family .......
I just did an online check at Napa. Their unit is 31.49 when you reference the Mopar number. I need to write this number down somewhere for the future.
Old 06-28-2008, 07:12 PM   #9 (permalink)
Just passing this on, if your idle is not set to the minimum req'd, you will get a no / low oil pressure reading on your gauge. Make sure your idle is correct before changing out the sender if this could be your problem?
1998 RAM 3500 QC SLT 4X4 12V/CTD
FF1063 is offline   Reply With Quote
Old 06-28-2008, 08:30 PM   #10 (permalink)
Been there done that.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
