Old 06-23-2008, 08:23 PM   #1 (permalink)
lance0730's Avatar
Winter starting procedure, in the summer?
My truck developed a tough start this last week...it will crank several times before it starts? touch the throttle a tad like in the cold winter months and it starts and runs fine? been doing this for the last week or so, doesnt bother me but i was wondering what would cause this? battery and alternator checked out at the napa so im thinking fuel area...any thoughts?
96 2500 GONE! New 1996 3500: Full billet DTT, pac brake, #10,timing,AFC spring kit,3GSK,5X12s,58/14 Hybrid, lockup controller,3 piece, 105,000MI
lance0730 is offline   Reply With Quote
Old 06-24-2008, 04:35 AM   #2 (permalink)
Moderator
Perhaps your idle rpms have dropped a little
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Both far from stock
Old 06-24-2008, 06:40 AM   #3 (permalink)
ykdave's Avatar
Check idle RPMs. If idle is even the slightest bit too low you can crank on that sucker all day before it starts (unless of course you give it some throttle!)
97 Ram 2500 / 5.9ctd / 5spd / nv4500 / 4x4 / np241
Starwheel cranked, no plate, autometer pyro and boost gauges, Single 4" stack, 33x10.5 Mud terrains, tons more to come
ykdave is online now   Reply With Quote
Old 06-24-2008, 05:40 PM   #4 (permalink)
lance0730's Avatar
ya, thats odd. its idling around 850ish
Old 06-25-2008, 10:21 AM   #5 (permalink)
Moderator
That should be good - if you can trust the tach. Factory Service Manual says not to.
You might want to bump it up a little and see if things change.
Personally I like giving my rigs a little throttle when starting vs. a higher idle.
Bill
'95 2500 4wd auto
Both far from stock
Old 06-25-2008, 01:34 PM   #6 (permalink)
clc
clc's Avatar
I think the manual for my 96 says 750 RPM at operating temperarture, sitting still (brake on), in drive, with the AC on. Like illflem wrote, the manual says you can't trust the tach.
I usually don't adjust the idle in the winter so I got used to a little pressure on the foot feed to crank it. If it bothers you try bumping up the idle a little.
96 3500 4WD, 47RE, gauges; 97 3500 4WD 47RE, gauges; 97 3500 2WD 5-spd; all club cab. 98.5 2500 2WD SB, 5-spd, gauges, quad cab
clc is offline   Reply With Quote
Old 06-26-2008, 01:16 AM   #7 (permalink)
i do it everytime. and im nearly positive its a low idle because if i turn the wheel near lock and put it in reverse it WILL stall everytime.
for me its a sacrifice. more chance of reverse stall but less "cruise control" effect.
my tach reads somewhere around 600-700 but will drop to about 400 or even slightly less, the first start of the day.
1970 300 SEL is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
