cold air intake options - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 06-11-2013, 01:39 PM Thread Starter
maxcu's Avatar
I am running a bone stock 12v and do not plan on doing any modification to the engine so is it worth the cash to get a cold air intake? Some other options I have looked at is a home made system or a K&N filter in the stock box. Just lookin for opinions here
1998 2500 12V
4x4 5 speed quad cab short box
maxcu is offline
post #2 of 11 (permalink) Old 06-11-2013, 02:04 PM
Nope. A cold air set up would only make more noise for you. Don't use a k&n though. Check out an AFE drop in. I'm a fan of their PG7 line. It is an oiled filter though. Some people don't like it. AFE also makes a good dry air filter too.
2002 Dodge 2500 4X4 QCLB, 5 speed, 5" exhaust with 30" FTE resonator, Edge Comp, Isspro EV gauges, Raptor 100, 230k miles
jdwest1978 is offline
post #3 of 11 (permalink) Old 06-11-2013, 03:22 PM
GAmes's Avatar
iTrader Score: 7 reviews
Discard your gasser mentality. A turbo heats the air by compressing it, no amount of "cold air" changes that. For that reason we have intercoolers. For stock applications the stock filter is a good as they get. Just don't forget to seal the edges where the filter mates to the box.
97 3500, 2 WD, G56, slightly bombed, 1.2 million miles. Started the second million on 8/24/13
GAmes is offline
post #4 of 11 (permalink) Old 06-11-2013, 04:01 PM Thread Starter
maxcu's Avatar
I see the wrong in my ways for calling them cold air intakes (Thanks GAmes)
So the claims of improved economy are just a load of marketing bs?
1998 2500 12V
maxcu is offline
post #5 of 11 (permalink) Old 06-11-2013, 04:18 PM
12valvedriver's Avatar
Yep. Won't do anything for mileage.
'90-Getrag 360, mostly stock
'97-NV4500, Kinda fast
'17-G56, all stock
12valvedriver is offline
post #6 of 11 (permalink) Old 06-11-2013, 04:37 PM Thread Starter
maxcu's Avatar
thanks for the input guys. saves me some cash
1998 2500 12V
maxcu is offline
post #7 of 11 (permalink) Old 06-11-2013, 04:50 PM
What were you looking to gain? Just more mpg? If so, look into bumping up your timing to around 16*
'17-G56, all stock
post #8 of 11 (permalink) Old 06-11-2013, 05:23 PM
CTK30's Avatar
I think there is an extra tall filter element, can't find the part number though, I think I'm going to get one myself
k1ob.com, 94 5spd, 356k miles, bhaf, 5" exhaust, 30" FTE resonator, efi live #100 fuel plate full forward stacked with smarty, Stock AFC, 3k gsk, stock timing, Super B single, 3" tubular intake horn, tow mirrors down, MG diesel VCO 5x10, torkteq ofv020
CTK30 is offline
post #9 of 11 (permalink) Old 06-11-2013, 05:26 PM Thread Starter
maxcu's Avatar
That is the way i am leaning right now. My buddys are pushing me to tweak the pump and get some more power but for the time I have into the truck to restore it I don't really want to mess with it. The plan at the moment is to build a nice highway driver so the more mpg the better
1998 2500 12V
maxcu is offline
post #10 of 11 (permalink) Old 06-11-2013, 06:27 PM
Sasquatch
crazyrunner33's Avatar
The stock intake is a cold air intake, you can add an extra vent to the cowl to bring in a little more air.
Here's a post from Illflem and the pictures of his install:
Modify Stock Airbox???
Another option is the BHAF, you can search it to find all the information you'd ever need. I like it because it's a large paper filter that flows well, paper is the best thing when it comes to keeping our engine safe. Only downside is that it's a hot air intake, it pulls in heat from the engine which means the air going to the turbo is not quite as dense.
'97 ECLB NV4500 compound mufflers, Banks stacked with Edge Juice w/Attitude, throttle sensitivity booster, lockup switch, wastegate delete
'10 VW Golf TDI DSG, High Performance DPF, low friction timing belt
crazyrunner33 is offline
The Following User Says Thank You to crazyrunner33 For This Useful Post:
WillM (06-11-2013)
post #11 of 11 (permalink) Old 06-12-2013, 05:36 AM
Mike337's Avatar
A must read before you waste money!!
http://www.genosgarage.com/GenosGara...irCleaners.pdf
1989 Ramcharger with 93 Cummins 6BT.
1992 Ramcharger with 93 Cummins 6BT.
1996 2500 Cummins 12v.
Mike337 is offline
The Following User Says Thank You to Mike337 For This Useful Post:
maxcu (06-13-2013)
