98 v10 to 12v chassis wiring - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 04-10-2013, 02:11 PM Thread Starter
Blue Oval's Avatar
I'm getting ready to pick up a 98 v10 with a bad engine to swap my 12v into. My thinking was to use my 96 dash, engine harness, pcm, etc to make things simple. I'm not sure whether the chassis wiring is the same on all 2nd gens though, such as exterior and interior lights. Anyone have experience here?
1998 qcsb v10->96 12v swap, auto
Blue Oval is offline
post #2 of 5 (permalink) Old 04-10-2013, 02:50 PM
GAmes's Avatar
iTrader Score: 7 reviews
Good luck. '98 is when Dodge went to switched grounds as opposed to the switched hot we have. If you swap out all the harnesses that might do the trick, but things like the ignition might not work. It would be worth your while to get a '98 FSM.
97 3500, 2 WD, G56, slightly bombed, 1.2 million miles. Started the second million on 8/24/13
GAmes is offline
post #3 of 5 (permalink) Old 04-10-2013, 02:57 PM
LNaugle's Avatar
Yes you have to swap everything, even steering column.
03 QC 4x4. Fuel & Compounds. Lifted. Spin Tech hub kit. South Bend Dual Disc.
LNaugle is offline
post #4 of 5 (permalink) Old 04-10-2013, 03:04 PM Thread Starter
Blue Oval's Avatar
But when swapping out the whole dash I will be able to get all the accessories hooked up to it? I guess another way to put it, would swapping the dash and 12v electronics be simpler than trying to get everything working with the v10 cluster?
Have you done a similar swap?
post #5 of 5 (permalink) Old 04-10-2013, 03:15 PM
LNaugle's Avatar
Yes, you have to use all of everything that was cummins.... I have done this swap cummins to cummins but in 96 to 02, 2wd to 4wd dually...
LNaugle is offline
