how much boost is to much - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 03-22-2013, 12:08 AM Thread Starter
I have a 98 12v extended cab, and i was just wondering how much boost i can run before i have to o-ring the head. I already have head studs and a slightly thicker gasket
gasgas250 is offline
post #2 of 17 (permalink) Old 03-22-2013, 12:09 AM Thread Starter
How much boost is to much boost
I have a 98 12v extended cab, and i was just wondering how much boost i can run before i have to o-ring the head. I already have head studs and a slightly thicker gasket.
post #3 of 17 (permalink) Old 03-22-2013, 12:53 AM
I am also interested ive read on stock bolts/gasket you can run 35 Psi max so curious at what point studs and thicker is not enough and when you have to o ring
98 QCLB 12V 5spd. plate MIA, Issipro pyro and boost, afc full mod, K&N cold air, tork tek ofv,18.5* timing, rebuilt updated NV4500, SBDD 3600, 5x.016 injectors, 024 dv's, 4k gsk, 60# valve springs, arp studs, Bd Super B special, BD boost boots,
cumminsrebel is offline
post #4 of 17 (permalink) Old 03-22-2013, 12:59 AM
I would say 45-50 psi max on studs and the head gasket ...
97 2500 12 valve - sold
2000 Extended cab F250 12 valve/nv4500 fummins project in the works...
97DieselVT is offline
post #5 of 17 (permalink) Old 03-22-2013, 04:11 AM
NotoriousBRT's Avatar
You're at the edge (maybe over it) of blowing a head gasket at 40psi with factory bolts. That said, I ran one for years at 50 psi on over torqued factory bolts with no o rings and never had an issue. A guy who built some hot Cummins engines for race trucks told me what to torque them to and it would hold. He was right. I broke everything else but that old 300,000 mile engine ran like a song and never gave a minute's trouble. My current truck let go after about 18 months of 45 psi at factory torque specs. I wish I could remember what the torque spec he gave me was and I would tell you.
1998.4 Dodge Ram 2500 4x4,NV4500 w/ 3850# SBC,Borg-Warner 64/71/14 charger,5x.014 injectors,Full cut DVs,4k GSK,60# springs,Mazzi Hulk wheels,Toyo Open Country 325/60R18 tires
NotoriousBRT is offline
post #6 of 17 (permalink) Old 03-22-2013, 08:40 AM
drooling piston's Avatar
I think your timing plays into this as well. The more you advance the timing the higher the cylinder pressures get.
other factors may include exhaust back pressure and intake air temperature.
If you are putting in hot air it wont expand as much as cool air would.
if the exhaust/turbo housing doesn't let all the spent air out easily, you wont have as much room in the cylinder for fresh cool air to come in.
people who block off the waste gate actuator on their stock hx35 will see higher boost psi numbers but those trucks dyno lower hp than trks who let the wastegate open and free up exhaust flow.
1997 ext cab 2500, 2WD, SLT, 5 gauges, #10 fuel plate, afc tuned, head studs, 60# valve springs, 5in exhaust. DDP 75HP injectors. timing 18*, 4k GSK, HE351VGT, 13spd road ranger trany, Home made twin ram style intake, sump drain with FASS fuel system
drooling piston is offline
The Following User Says Thank You to drooling piston For This Useful Post:
NotoriousBRT (03-22-2013)
post #7 of 17 (permalink) Old 03-22-2013, 10:31 AM Thread Starter
My timing is set at 15 degrees and I have the bd super single, so I don't imagine drive pressure is really an issue right now
post #8 of 17 (permalink) Old 03-22-2013, 12:43 PM
samwash's Avatar
Timing plays a major role. I agree with drooling piston. 12 valve heads are said told hold more boost than 24 valves also. Another big role on the head gasket is prolonged egt's. More expansion and contraction not to mention the heat against the fire ring in the stock gasket.
2004 Ram 2500 QQLB 6 Speed, Smarty SSR, Bag of Parts, BHAF, MBRP 4'' TBE
1996 Ram 2500 QQLB ATS auto DDP 90hp sticks
1995 Ram 2500 RCLB 5 speed
samwash is offline
post #9 of 17 (permalink) Old 03-22-2013, 02:36 PM
how you like the bd super single spool quick with easy egt's been lookin at that one some myself
post #10 of 17 (permalink) Old 03-22-2013, 02:38 PM
12valvedriver's Avatar
It all depends on how you treat it. With my setup I see 65 lbs on just studs and no problems yet. I also rarely see that kinda boost and when I do, I am sure to have it good and warm. Never let it see boost when it is cold.
'97-5" straight #100 ff, 19*, 4k gsk, AD II 165, valair dd clutch, 1-3/8" billet input, ARP studs, 60#, BD Super B over s475, 024's, Mayville WI best 5x14's,
'90-4" exhaust, kdp killed, pacbrake, 60 lb springs
12valvedriver is offline
post #11 of 17 (permalink) Old 03-22-2013, 03:52 PM
VP of the dry side
cumminsrulez's Avatar
Re: how much boost is to much
What 12valvedriver said. I never get on my truck when it isn't up to full operating temp. On stock timing my truck ran 45 psi for a couple months. Then saw 40psi with 16* timing. For months. When I installed dvs it saw 50psi with the wastegate closed and held. It only saw that twice. Then with the new turbo its seen 55psi once and normally holds about 45psi. But it rarely sees that. I drive my truck easy. And never get on it when it isn't up to full temp
97,2wd, auto swapped, Moss Green, 211k, s&b,4in with muffler stock tip
(stealth mode engaged
) ,afc mods, kdp,egt boost fp dp,22*,Haisley 5k gsk-60pounders,traction bars, A1 studs+Oring'd block, P&P, A1000 custom fuel setup,5x.018 SAC 145* 300 bar,.025 dvs, 64.5/68/.83 t4 sxe 50mm jgs gate/w screamer pipe
Originally Posted by dvst8r View Post
Dying is always a way bigger concern than egt's...
cumminsrulez is offline
post #12 of 17 (permalink) Old 03-22-2013, 09:36 PM Thread Starter
the bd single is wicked i never see temps over 1200, I have the fuel to air ratio matched prity good also very little smoke at 40 psi
