Old 07-10-2006, 01:35 PM   #25 (permalink)
hosebib's Avatar
The truck made to the lake and back....tps acted up about 1/2 hour out , convertor kept unlocking untill i gave it more throttle. Speaking of throttle , didn't have much other than about 1/4 . Still had enough to keep going, so I kept going. Realized at the lake that the boost line to the afc was kinked beyond a lake repair. I assume thats why there's no response beyond 1/4 throttle. Crappy milage too. WILL FIX AND ADVISE.
1995 12v Custom Auto(Billit TC, clutches and valve body mods) 4x4, reman dc 215 pump and injectors, GSK, timing set to 17* , home ground fuel plate to a tst #10 , not in sock location
1994 Dakota 318 4x4 , mopar perf intake and headers 88000 km
hosebib is offline   Reply With Quote
Old 07-10-2006, 03:13 PM   #26 (permalink)
hosebib's Avatar
Angry
just looked at it again at lunch, there is a bit of a kink in the line , but it should still allow boost through it . I moved the plate back to the stock location at the lake and thats when i saw the kink, but now I'n not sure if thats where the problem is. If I understand the pump correctly, It needs a boost signal to the afc so it can help regulate the fuel to the boost??? 12v experiance is not yet my specialty, so I thank you for any sugestions and help.
Old 08-10-2006, 04:32 PM   #27 (permalink)
hosebib's Avatar
Finally..after i put gauges in and saw only 600*, I decided to make a baseline adjustment and moved the afc and plate full foreward. It will break the new BF mud terrian tires loose and has plenty of throttle response. Just have to do some afc and starwheel adjustments for smoke .Also It easily reached 1200* , so I'll have to detune it or keep an eye on the egt . Now I'm dreaming of exhaust mods and thinking of grinding the plate from the 160 pump. I might find a warranty exhaust and tail pipe from a 2003 and weld the flange from the 95 down pipe to the 2003. Would a turbo from a 2002 HO lower the EGT ?
Old 08-10-2006, 06:35 PM   #28 (permalink)
Easily reaching 1200 is not exactly engine-melting territory. I've pegged my egt gauge at 1500 quite a few times, for short periods anyway. I'm far from alone in doing that, too.
'98 12v 2wd quadcab dually with 271k, BHAF, #0 plate shoved all the way forward, afc arm removed from pump, 3k gsk, timing set at 16.5 deg, 4" mandrel bent exhaust, new 3.54's and detroit locker, southbend dual disk clutch, fogger nozzle with #82 jet plumbed into air horn, htb2-64 turbo, has broken spider gears in two dana 80's so far, has run 14.65 at 98 and dynoed at 450 hp 906 ft/lb torque in 4th gear on bottle, 399 hp 814 ft/lb in 5th gear without bottle
v8440 is offline   Reply With Quote
Old 08-11-2006, 08:57 PM   #29 (permalink)
hosebib's Avatar
Does anyone know the limits for meltdown and the time it takes at that temp to do it. For example, Is 1200* for 10 minutes too long ? or 1100 for an hour too much? 1600* instant melt ?
Old 08-11-2006, 11:45 PM   #30 (permalink)
The way I understand it is that you can run up to about 1350* all day long and supposedly not hurt anything. I don't think I would try that much heat though .........................
Tom05 is offline   Reply With Quote
