3500 to 2500 swap - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 12-28-2012, 09:49 PM Thread Starter
The 10th Man
Cowboy303's Avatar
3500 to 2500 swap
OK after searching for a while I still have some questions.
What would be involved in taking a '97 4x4 3500 and turning it into a 4x4 2500?
I have a '97 2wd 2500 I can take parts from.
  • SRW bed
  • Rear axle
  • Do I need to do anything with the front axle?
  • Rear Drive shaft?
And what else?
I have the truck in my sig and would like a 4x4 2500 and my buddy has a 4x4 3500 for pretty cheap so I was thinking on making it a 2500 and make my current truck a 3500 and sell it, or just part it out.
Thanks, if you have any questions please ask.
- '96 2500 ECLB
3.54's, Cooper AT3 265's, Head Securing Devices @ 130ftlb, Custom GSK,
, #10 plate,
, AFC Stop-Bolt,
, OBA, OBP,
, Str box brace,
, couple gauges.
Cowboy303 is offline
post #2 of 12 (permalink) Old 12-28-2012, 10:00 PM
Brandon .30-06's Avatar
Why would you downsize your truck?
Sent from my iPhone using AutoGuide.com App
2014 RAM 3500 LIMITED SRW CC in Black
LEVEL 4 CHRYSLER TECH/ MASTER DIESEL TECH
Brandon .30-06 is offline
post #3 of 12 (permalink) Old 12-28-2012, 10:11 PM Thread Starter
The 10th Man
Cowboy303's Avatar
I don't tow much weight, and don't like using 2 extra tires.
I have a 3500 already so if I need to tow bigger then that's an option.
And this will probably be a long term DD for me.
Sorry, probably should have said all that in my first post.
Thank you!
- '96 2500 ECLB
, #10 plate,
, AFC Stop-Bolt,
, OBA, OBP,
, Str box brace,
, couple gauges.
post #4 of 12 (permalink) Old 12-28-2012, 10:45 PM
Get ya some Super Singles and 8" bullhauler stacks and you would be good to go!!
I am failing to see why a person would want to make a light duty 1 ton? Them extra tires do serve a purpose. I keep mine in the tire rotation. Why not just get a 4x4 2500 instead of down grading a perfectly good tonner... Just kinda baffling to me. But to each his own and what ever trips your trigger. Not trying to sound like a jerk but it is just kinda weird to me is all.
It is probably a lot easier than you think. Depending on what kind of axles is on the 2wd and what is on the 4x4. If they are the same axle you may be able to just change out hubs.... I may be wrong, someone correct if I am.
2004 Ram 3500 stock, exception of elect fans, aFe Exhaust, K&N CAI, S&B intake elbow, and AirDog Lift pump. 323,000 and still going.
midwest_runner is offline
post #5 of 12 (permalink) Old 12-28-2012, 11:33 PM
mthomp1's Avatar
His 2500 likely has a Dana 70 being that it's an auto, while the 3500 will have a Dana 80.
2001 Ram 2500, 24 valve, 47RE, 4x4, 3.55, short bed, quad cab, all stock
1996 Ram 3500 cab & chassis, 12 valve, NV4500, 4.10, flatbed, single cab, all stock
mthomp1 is offline
post #6 of 12 (permalink) Old 12-29-2012, 12:12 AM
witegoat's Avatar
Basically all you're looking to do is turn a dually to a single wheel. Use the search function and try "drw to srw swap"
Sent from my Android
1997 cab and chassis 5 speed, no plate, afc tuned, boost elbow, BHAF, stock hx35, EGT, boost, fuel pressure gauges, coming soon:13" flywheel and single disc south bend clutch
witegoat is offline
post #7 of 12 (permalink) Old 12-29-2012, 12:24 AM
JeepsRcool's Avatar
Dont know about the front, but for the back just bolt one some stock rims. Or regular SRW rims, it is only 3 inches overall wider.
1995 Dodge 12v ECLB Auto 4X4 240k KDP Tabbed, BHAF, 7x.012's, 16*s
JeepsRcool is offline
post #8 of 12 (permalink) Old 12-29-2012, 01:57 AM Thread Starter
The 10th Man
Cowboy303's Avatar
Thank you sir, I was looking with 3500 and 2500 I put in what you said and got what I was looking for, thanks.
- '96 2500 ECLB
, #10 plate,
, AFC Stop-Bolt,
, OBA, OBP,
, Str box brace,
, couple gauges.
post #9 of 12 (permalink) Old 12-29-2012, 01:58 AM Thread Starter
The 10th Man
Cowboy303's Avatar
Thank you, That's what I wanted to know.
- '96 2500 ECLB
, #10 plate,
, AFC Stop-Bolt,
, OBA, OBP,
, Str box brace,
, couple gauges.
post #10 of 12 (permalink) Old 12-29-2012, 11:44 AM Thread Starter
The 10th Man
Cowboy303's Avatar
OK guys thanks for all the help!
I found this thread that has some good info, if somebody searches for 2500/3500 instead of srw/drw like me and find this thread then hear you go,
single rear wheel swap...
if that doesn't help then search for "drw to srw swap" that gets you a lot of info.
Thanks all
- '96 2500 ECLB
, #10 plate,
, AFC Stop-Bolt,
, OBA, OBP,
, Str box brace,
, couple gauges.
post #11 of 12 (permalink) Old 12-29-2012, 11:12 PM
Quest's Avatar
iTrader Score: 4 reviews
we are dreaming about converting our 2500 to dually and you want to do the opposite
please let us know what are you planning to do with the extra parts. Very interested on the fenders
1994 2500 Dually conversion, Dana 80 DRW 3:54, 3rd Gen dually wheels, 3rd Gen Towing Mirrors, 50Gallons greasecar kit, Tork OFV040HP, 7x0.09 PDD Injectors, 0.55 Delivery Valves, 4K GSK, AFC Live Stage 2, 4" straight exhaust, 95GPM HD Fass System, AFE CAI FORCE PRO 5R Stage-2, Firestone Rear Airbags, Honrblasters Shockers w/ Home made Onboard system.
Over 1.318 million miles
AND always under construction...
Quest is offline
post #12 of 12 (permalink) Old 12-30-2012, 12:07 AM Thread Starter
The 10th Man
Cowboy303's Avatar
Here's the whole story, I NEED A 4X4.
My buddy has a 3500 4x4 5spd that has a bad IP (he thinks it's bad I told him I would look into it and see so I can pay him accordingly). He really likes the truck and does not want to sell it so he really wants me to take it, and I know he does not beat on this truck so it's kind of a win win.
And then swap the SRW parts from my 2wd auto 2500 so I can have a 4x4 5spd 2500. And then put all the DRW stuff on my 2wd auto making it a 3500 (still perfect running truck).
If I have to put my IP in the truck then I might have to part it out so I don't give it away.
The demand out here for a 2wd is not good and being a auto does not help.
Anyway if your interested I might now of a DRW bed for you I'd have to check the condition of it.
- '96 2500 ECLB
, #10 plate,
, AFC Stop-Bolt,
, OBA, OBP,
, Str box brace,
, couple gauges.
